Need help troubleshooting phantom enabled triggers
Whenever I restart BTT, I notice that there are temporary variables being set in BTT from an old Floating Menu that I created many months ago and have since deleted, and yet, these temporary variables persistently get re-set on BTT restart.
These temporary variables are related to my current mouse position. In my BTT Floating Menu, I was setting these variables using the cliclick CLI: GitHub - BlueM/cliclick: macOS CLI tool for emulating mouse and keyboard events.
I looked all through my BTT configuration and couldn't find anything related to this old Floating Menu, nor any Triggers which are executing the cliclick CLI.
To troubleshoot, I started looking into the files in ~/Library/Application Support/BetterTouchTool. That's when I finally found a clue!
╰─❯ sqlite3 "btt_data_store.version_5_304_build_2025040803" "SELECT * FROM ZBTTBASEENTITY;" | grep cliclick
32445|9|2|||||||||||||||||||||||||||||||||||||||||-1|0|1|773|1|21|-1|0|0|-1|0|0|0|0|0||32388||32432|||||||||||||||||||||||||||||||||||||||||||||||0.0|0.0|||||||||||7EC4DE89-EB50-4F31-9C05-FF05E37606BB||||||||||||||||||||||||||||||||no-name-7EC4DE8|Standard Item|Menu Item: no-name-7EC4DE8|||-1|||||||||||||||||||||||||{"BTTMenuItemBorderColorDark":"255.000000, 255.000000, 255.000000, 255.000000","BTTMenuItemIconColor1":"255.000000, 255.000000, 255.000000, 255.000000","BTTMenuScriptSettings":{"BTTScriptType":3,"BTTAppleScriptString":"async function itemScript(itemUUID) {\n  let shellScript = `/opt/homebrew/bin/cliclick p`;\n\n  let shellScriptWrapper = {\n    script: shellScript, // mandatory\n    launchPath: \"/bin/bash\", //optional - default is /bin/bash\n    parameters: \"-c\", // optional - default is -c. If you use multiple parameters please separate them by ;; e.g. -c;;date\n    environmentVariables: \"\", //optional e.g. VAR1=/test/;VAR2=/test2/;\n  };\n\n  // this will execute the Apple Script and store the result in the result variable.\n  let result = await runShellScript(shellScriptWrapper);\n  let coords = result.split(\",\");\n  let x = coords[0];\n  let y = coords[1];\n  let content = {\n    BTTMenuItemText: `${x}, ${y}`,\n  };\n  return JSON.stringify(content);\n}\n","BTTScriptFunctionToCall":"itemScript","BTTScriptLocation":0,"BTTAppleScriptUsePath":false,"BTTJavaScriptUseIsolatedContext":false},"BTTMenuItemBackgroundColor":"108.442, 96.000, 190.435, 166.991","BTTMenuTextMinimumScaleFactor":0.29999999999999999,"BTTMenuScriptAlwaysRunOnFirstLoad":1,"BTTMenuItemBackgroundType":4,"BTTMenuItemMaxHeight":50,"BTTMenuHoverEndAnimationDuration":0.14999999999999999,"BTTMenuItemMaxWidth":200,"BTTLastChangeUUID":"02F7B120-9BCF-4C03-9B59-EFF6EF92164A","BTTMenuItemBorderColorHover":"255.000000, 255.000000, 255.000000, 255.000000","BTTMenuItemBorderColor":"255.000000, 255.000000, 255.000000, 255.000000","BTTMenuItemMinHeight":50,"BTTMenuItemBackgroundColorDark":"108.442, 96.000, 190.435, 166.991","BTTMenuItemVisibleWhileActive":1,"BTTMenuElementIdentifier":"no-name-7EC4DE8","BTTMenuItemVisibleWhileInactive":1,"BTTMenuItemMinWidth":100,"BTTMenuItemBackgroundTypeDark":4,"BTTMenuAttributedText":"{\\rtf1\\ansi\\ansicpg1252\\cocoartf2821\n\\cocoatextscaling0\\cocoaplatform0{\\fonttbl\\f0\\fnil\\fcharset0 HelveticaNeue;}\n{\\colortbl;\\red255\\green255\\blue255;\\red255\\green255\\blue255;}\n{\\*\\expandedcolortbl;;\\cssrgb\\c100000\\c100000\\c100000;}\n\\deftab720\n\\pard\\pardeftab720\\qc\\partightenfactor0\n\n\\f0\\fs44 \\cf2 \\expnd0\\expndtw0\\kerning0\nNew Item}","BTTMenuScriptUpdateInterval":0.5,"BTTMenuItemBorderColorHoverDark":"255.000000, 255.000000, 255.000000, 255.000000","BTTMenuAppearanceStyle":0,"BTTMenuItemBackgroundColorHover":"90, 90.000, 180, 166.991","BTTMenuAlwaysUseLightMode":1,"BTTMenuCategoryBackground":1,"BTTMenuCategoryItemSizing":1,"BTTMenuScriptAlwaysRunOnAppear":1,"BTTMenuItemSelectedTab":1,"BTTMenuItemScriptActive":1,"BTTMenuHoverStartAnimationDuration":0.14999999999999999,"BTTMenuItemBackgroundColorHoverDark":"90, 90.000, 180, 166.991"}|||||||760529327.776166|||||||||0.0||||||||||||0|0.0
Digging deeper...
╰─❯ sqlite3 -json "btt_data_store.version_5_304_build_2025040803" "SELECT * FROM ZBTTBASEENTITY WHERE ZUNIQUEIDENTIFIER = '7EC4DE89-EB50-4F31-9C05-FF05E37606BB';" | jq '.[]'
  "Z_PK": 32445,
  "Z_ENT": 9,
  "Z_OPT": 2,
  "ZAUTOINVERTICON": null,
  "ZDISABLEBTT": null,
  "ZDISABLESFHORIZONTALSCROLLING": null,
  "ZDISABLESFSCROLLING": null,
  "ZDISABLEWINDOWSNAPPING": null,
  "ZOLDSHORTCUTSENDING": null,
  "ZPROCESSMATCHMODE": null,
  "ZTOUCHBARMODE": null,
  "ZDISABLEAXOBSERVER": null,
  "ZDISABLEBTT1": null,
  "ZDISABLECLIPBOARDMANAGER": null,
  "ZDISABLESFHORIZONTALSCROLLING1": null,
  "ZDISABLESFSCROLLING1": null,
  "ZDISABLEWINDOWSNAPPING1": null,
  "ZOLDSHORTCUTRECEIVING": null,
  "ZOLDSHORTCUTSENDING1": null,
  "ZTOUCHBARMODE1": null,
  "ZBELONGSTOAPP": null,
  "ZBELONGSTOPRESET": null,
  "ZBUILTIN": null,
  "ZDISPLAYID": null,
  "ZIGNOREORIGIN": null,
  "ZMAINDISPLAY": null,
  "ZMODEL": null,
  "ZVENDOR": null,
  "ZDASHEDBORDER": null,
  "ZINVISIBLE": null,
  "ZNEEDSALT": null,
  "ZNEEDSCMD": null,
  "ZNEEDSCTRL": null,
  "ZNEEDSFN": null,
  "ZNEEDSSHIFT": null,
  "ZPREVIEWBORDERWIDTH": null,
  "ZROUNDNESS": null,
  "ZSHOWPICTOGRAM": null,
  "ZTEXTSHADOW": null,
  "ZBELONGSTOPRESET1": null,
  "ZSITSONDISPLAY": null,
  "ZSNAPSTODISPLAY": null,
  "ZASSOCIATEDGESTURE": null,
  "ZACTION": -1,
  "ZDISPLAYORDER": 0,
  "ZENABLEDNEW": 1,
  "ZGESTURETYPE": 773,
  "ZISENABLED": 1,
  "ZISTOUCHPAD": 21,
  "ZKEYCODE": -1,
  "ZLOCKED": 0,
  "ZMERGE": 0,
  "ZMODIFIERKEYS": -1,
  "ZMODIFIERKEYSALTERNATE": 0,
  "ZMODIFIERMODE": 0,
  "ZNOTESINSTEAD": 0,
  "ZNUMBER1": 0,
  "ZORDER": 0,
  "ZTRIGGERONDOWN": null,
  "ZBELONGSTOPRESET2": 32388,
  "ZKEYSEQUENCE": null,
  "ZPARENT": 32432,
  "ZTRAIT": null,
  "ZCODE": null,
  "ZDOWN": null,
  "ZDOWNTIMEREQUIRED": null,
  "ZORDERRELEVANT": null,
  "ZREQUIRED": null,
  "ZBELONGSTOKEYSEQUENCEDOWN": null,
  "ZBELONGSTOKEYSEQUENCEMIXED": null,
  "ZBELONGSTOKEYSEQUENCEUP": null,
  "ZALLOWRETRIGGER": null,
  "ZDELETEAFTERWARDS": null,
  "ZKEYCOUNT": null,
  "ZKEYBOARDSCOPE": null,
  "ZKEYBOARDTYPE": null,
  "ZNUMBEROFREQUIRED": null,
  "ZUNDOAFTERWARDS": null,
  "ZBELONGSTOGESTURE": null,
  "ZACTIVATED": null,
  "ZORDER1": null,
  "ZTRIGGERTRAIT": null,
  "ZACTION1": null,
  "ZISENABLED1": null,
  "ZKEYCODE1": null,
  "ZMODIFIER": null,
  "ZORDER2": null,
  "ZICONHEIGHT": null,
  "ZICONWIDTH": null,
  "ZITEMPLACEMENT": null,
  "ZNUMBER11": null,
  "ZNUMBER2": null,
  "ZNUMBER4": null,
  "ZNUMBER5": null,
  "ZONLYICON": null,
  "ZPREVENTRECURSIVETRIGGERS": null,
  "ZSHOWHUD": null,
  "ZTRIGGERPATTERN": null,
  "ZTRIGGERFORPRESET": null,
  "Z_FOK_ASSOCIATEDGESTURE": null,
  "Z_FOK_BELONGSTOKEYSEQUENCEDOWN": null,
  "Z_FOK_BELONGSTOKEYSEQUENCEMIXED": null,
  "Z_FOK_BELONGSTOKEYSEQUENCEUP": null,
  "Z_FOK_BELONGSTOGESTURE": null,
  "ZANIMATIONDURATION": null,
  "ZPICTOGRAMDISTANCEFROMBOTTOM": null,
  "ZPICTOGRAMDISTANCEFROMLEFT": null,
  "ZPICTOGRAMSIZE": null,
  "ZREPEATDELAY": 0.0,
  "ZREPEATRATE": 0.0,
  "ZDOWNTIME": null,
  "ZTIME": null,
  "ZAFTERTIME": null,
  "ZBEFORETIME": null,
  "ZBETWEENTIME": null,
  "ZFIXEDWIDTH": null,
  "ZITEMPADDING": null,
  "ZNOTOUCHTIMEOUT": null,
  "ZNUMBER3": null,
  "ZUPDATEINTERVAL": null,
  "ZUNIQUEIDENTIFIER": "7EC4DE89-EB50-4F31-9C05-FF05E37606BB",
  "ZBUNDLEIDENTIFIER": null,
  "ZCUSTOMVALUE": null,
  "ZNAME": null,
  "ZPROCESSNAME": null,
  "ZWINDOWNAME": null,
  "ZCUSTOMVALUE1": null,
  "ZRESOLUTION": null,
  "ZSCREENFRAME": null,
  "ZSCREENSIZE": null,
  "ZSERIALNUMBER": null,
  "ZAPPBUNDLEIDENTIFIER": null,
  "ZCUSTOM1": null,
  "ZCUSTOM2": null,
  "ZDRAGPOINTBORDERCOLOR": null,
  "ZDRAGPOINTCOLOR": null,
  "ZDRAGPOINTFRAME": null,
  "ZDRAGPOINTHIGHLIGHTCOLOR": null,
  "ZKEYBOARDSHORTCUT": null,
  "ZPREVIEWBORDERCOLOR": null,
  "ZPREVIEWCOLOR": null,
  "ZPREVIEWFRAME": null,
  "ZUUID": null,
  "ZBUNDLEIDENTIFIER1": null,
  "ZCUSTOM11": null,
  "ZCUSTOM21": null,
  "ZCUSTOM3": null,
  "ZNAME1": null,
  "ZNAME2": null,
  "ZOTHER": null,
  "ZADDITIONALACTIONSTRING": null,
  "ZADDITIONALINTEGER": null,
  "ZADDITIONALSTRING": "no-name-7EC4DE8",
  "ZDESC": "Standard Item",
  "ZGESTURECONFIG": "Menu Item: no-name-7EC4DE8",
  "ZLAUNCHPATH": null,
  "ZNOTES": null,
  "ZSHORTCUT": "-1",
  "ZCHARACTER": null,
  "ZMETA": null,
  "ZCOLOR": null,
  "ZNAME3": null,
  "ZLAUNCHPATH1": null,
  "ZSHORTCUT1": null,
  "ZBEZIERNAME": null,
  "ZCOLOR2": null,
  "ZCOMERSSI": null,
  "ZHUDDETAILTEXT": null,
  "ZHUDTEXT": null,
  "ZJSON": null,
  "ZLEAVERSSI": null,
  "ZMESSAGE": null,
  "ZNAMED_TRIGGER": null,
  "ZREGEX": null,
  "ZTRAIT1": null,
  "ZLABEL": null,
  "ZACTIVATIONPREDICATE": null,
  "ZICONDATA": null,
  "ZCONTENT": null,
  "ZACTIONDATA": null,
  "ZICONDATA1": null,
  "ZICONDATA2": null,
  "ZICONDATA3": "\u0001{\"BTTMenuItemBorderColorDark\":\"255.000000, 255.000000, 255.000000, 255.000000\",\"BTTMenuItemIconColor1\":\"255.000000, 255.000000, 255.000000, 255.000000\",\"BTTMenuScriptSettings\":{\"BTTScriptType\":3,\"BTTAppleScriptString\":\"async function itemScript(itemUUID) {\\n  let shellScript = `/opt/homebrew/bin/cliclick p`;\\n\\n  let shellScriptWrapper = {\\n    script: shellScript, // mandatory\\n    launchPath: \\\"/bin/bash\\\", //optional - default is /bin/bash\\n    parameters: \\\"-c\\\", // optional - default is -c. If you use multiple parameters please separate them by ;; e.g. -c;;date\\n    environmentVariables: \\\"\\\", //optional e.g. VAR1=/test/;VAR2=/test2/;\\n  };\\n\\n  // this will execute the Apple Script and store the result in the result variable.\\n  let result = await runShellScript(shellScriptWrapper);\\n  let coords = result.split(\\\",\\\");\\n  let x = coords[0];\\n  let y = coords[1];\\n  let content = {\\n    BTTMenuItemText: `${x}, ${y}`,\\n  };\\n  return JSON.stringify(content);\\n}\\n\",\"BTTScriptFunctionToCall\":\"itemScript\",\"BTTScriptLocation\":0,\"BTTAppleScriptUsePath\":false,\"BTTJavaScriptUseIsolatedContext\":false},\"BTTMenuItemBackgroundColor\":\"108.442, 96.000, 190.435, 166.991\",\"BTTMenuTextMinimumScaleFactor\":0.29999999999999999,\"BTTMenuScriptAlwaysRunOnFirstLoad\":1,\"BTTMenuItemBackgroundType\":4,\"BTTMenuItemMaxHeight\":50,\"BTTMenuHoverEndAnimationDuration\":0.14999999999999999,\"BTTMenuItemMaxWidth\":200,\"BTTLastChangeUUID\":\"02F7B120-9BCF-4C03-9B59-EFF6EF92164A\",\"BTTMenuItemBorderColorHover\":\"255.000000, 255.000000, 255.000000, 255.000000\",\"BTTMenuItemBorderColor\":\"255.000000, 255.000000, 255.000000, 255.000000\",\"BTTMenuItemMinHeight\":50,\"BTTMenuItemBackgroundColorDark\":\"108.442, 96.000, 190.435, 166.991\",\"BTTMenuItemVisibleWhileActive\":1,\"BTTMenuElementIdentifier\":\"no-name-7EC4DE8\",\"BTTMenuItemVisibleWhileInactive\":1,\"BTTMenuItemMinWidth\":100,\"BTTMenuItemBackgroundTypeDark\":4,\"BTTMenuAttributedText\":\"{\\\\rtf1\\\\ansi\\\\ansicpg1252\\\\cocoartf2821\\n\\\\cocoatextscaling0\\\\cocoaplatform0{\\\\fonttbl\\\\f0\\\\fnil\\\\fcharset0 HelveticaNeue;}\\n{\\\\colortbl;\\\\red255\\\\green255\\\\blue255;\\\\red255\\\\green255\\\\blue255;}\\n{\\\\*\\\\expandedcolortbl;;\\\\cssrgb\\\\c100000\\\\c100000\\\\c100000;}\\n\\\\deftab720\\n\\\\pard\\\\pardeftab720\\\\qc\\\\partightenfactor0\\n\\n\\\\f0\\\\fs44 \\\\cf2 \\\\expnd0\\\\expndtw0\\\\kerning0\\nNew Item}\",\"BTTMenuScriptUpdateInterval\":0.5,\"BTTMenuItemBorderColorHoverDark\":\"255.000000, 255.000000, 255.000000, 255.000000\",\"BTTMenuAppearanceStyle\":0,\"BTTMenuItemBackgroundColorHover\":\"90, 90.000, 180, 166.991\",\"BTTMenuAlwaysUseLightMode\":1,\"BTTMenuCategoryBackground\":1,\"BTTMenuCategoryItemSizing\":1,\"BTTMenuScriptAlwaysRunOnAppear\":1,\"BTTMenuItemSelectedTab\":1,\"BTTMenuItemScriptActive\":1,\"BTTMenuHoverStartAnimationDuration\":0.14999999999999999,\"BTTMenuItemBackgroundColorHoverDark\":\"90, 90.000, 180, 166.991\"}",
  "ZBEZIERPATH": null,
  "ZHUDIMAGE": null,
  "ZHIDDEN": null,
  "ZTOUCHBARMODIFIERUNHIDE": null,
  "ZDISABLEDRAWINGS": null,
  "ZDISABLEMIDI": null,
  "ZUPDATEDAT": 760529327.7761659623,
  "ZNOTCHBARMODE": null,
  "ZNOTCHBARMODIFIERUNHIDE": null,
  "ZDISABLEGLOBALTRIGGERS": null,
  "ZDISABLEGLOBALTRIGGERS1": null,
  "ZCONDITIONS": null,
  "ZDISPLAYNAME": null,
  "ZDISPLAYUUID": null,
  "ZHUDSFSYMBOL": null,
  "ZACTIONNUMBER": 0.0,
  "ZMINIMUMDOWNTIME": null,
  "ZACTIONDATA2": null,
  "ZACTIONLABEL": null,
  "ZEXCLUDE": null,
  "ZCHEATSHEETCONFIG": null,
  "ZUSECUSTOMTRIGGERLABEL": null,
  "ZSTYLEDATA": null,
  "ZCHEATSHEETFORMOPEN": null,
  "ZUSECUSTOMACTIONLABEL": null,
  "ZTRIGGERLABEL": null,
  "ZLASTUSED": null,
  "ZACTIONCATEGORY": 0,
  "ZALLOWCONTINUEDTIME": 0.0
The content of ZICONDATA3...
  "BTTMenuItemBorderColorDark": "255.000000, 255.000000, 255.000000, 255.000000",
  "BTTMenuItemIconColor1": "255.000000, 255.000000, 255.000000, 255.000000",
  "BTTMenuScriptSettings": {
    "BTTScriptType": 3,
    "BTTAppleScriptString": "async function itemScript(itemUUID) {\n  let shellScript = `/opt/homebrew/bin/cliclick p`;\n\n  let shellScriptWrapper = {\n    script: shellScript, // mandatory\n    launchPath: \"/bin/bash\", //optional - default is /bin/bash\n    parameters: \"-c\", // optional - default is -c. If you use multiple parameters please separate them by ;; e.g. -c;;date\n    environmentVariables: \"\", //optional e.g. VAR1=/test/;VAR2=/test2/;\n  };\n\n  // this will execute the Apple Script and store the result in the result variable.\n  let result = await runShellScript(shellScriptWrapper);\n  let coords = result.split(\",\");\n  let x = coords[0];\n  let y = coords[1];\n  let content = {\n    BTTMenuItemText: `${x}, ${y}`\n  };\n  return JSON.stringify(content);\n}\n",
    "BTTScriptFunctionToCall": "itemScript",
    "BTTScriptLocation": 0,
    "BTTAppleScriptUsePath": false,
    "BTTJavaScriptUseIsolatedContext": false
  "BTTMenuItemBackgroundColor": "108.442, 96.000, 190.435, 166.991",
  "BTTMenuTextMinimumScaleFactor": 0.29999999999999999,
  "BTTMenuScriptAlwaysRunOnFirstLoad": 1,
  "BTTMenuItemBackgroundType": 4,
  "BTTMenuItemMaxHeight": 50,
  "BTTMenuHoverEndAnimationDuration": 0.14999999999999999,
  "BTTMenuItemMaxWidth": 200,
  "BTTLastChangeUUID": "02F7B120-9BCF-4C03-9B59-EFF6EF92164A",
  "BTTMenuItemBorderColorHover": "255.000000, 255.000000, 255.000000, 255.000000",
  "BTTMenuItemBorderColor": "255.000000, 255.000000, 255.000000, 255.000000",
  "BTTMenuItemMinHeight": 50,
  "BTTMenuItemBackgroundColorDark": "108.442, 96.000, 190.435, 166.991",
  "BTTMenuItemVisibleWhileActive": 1,
  "BTTMenuElementIdentifier": "no-name-7EC4DE8",
  "BTTMenuItemVisibleWhileInactive": 1,
  "BTTMenuItemMinWidth": 100,
  "BTTMenuItemBackgroundTypeDark": 4,
  "BTTMenuAttributedText": "{\\rtf1\\ansi\\ansicpg1252\\cocoartf2821\n\\cocoatextscaling0\\cocoaplatform0{\\fonttbl\\f0\\fnil\\fcharset0 HelveticaNeue;}\n{\\colortbl;\\red255\\green255\\blue255;\\red255\\green255\\blue255;}\n{\\*\\expandedcolortbl;;\\cssrgb\\c100000\\c100000\\c100000;}\n\\deftab720\n\\pard\\pardeftab720\\qc\\partightenfactor0\n\n\\f0\\fs44 \\cf2 \\expnd0\\expndtw0\\kerning0\nNew Item}",
  "BTTMenuScriptUpdateInterval": 0.5,
  "BTTMenuItemBorderColorHoverDark": "255.000000, 255.000000, 255.000000, 255.000000",
  "BTTMenuAppearanceStyle": 0,
  "BTTMenuItemBackgroundColorHover": "90, 90.000, 180, 166.991",
  "BTTMenuAlwaysUseLightMode": 1,
  "BTTMenuCategoryBackground": 1,
  "BTTMenuCategoryItemSizing": 1,
  "BTTMenuScriptAlwaysRunOnAppear": 1,
  "BTTMenuItemSelectedTab": 1,
  "BTTMenuItemScriptActive": 1,
  "BTTMenuHoverStartAnimationDuration": 0.14999999999999999,
  "BTTMenuItemBackgroundColorHoverDark": "90, 90.000, 180, 166.991"
The content of BTTMenuScriptSettings.BTTAppleScriptString...
    launchPath: "/bin/bash", // optional - default is /bin/bash
    parameters: "-c", // optional - default is -c. If you use multiple parameters please separate them by ;; e.g. -c;;date
    environmentVariables: "", // optional e.g. VAR1=/test/;VAR2=/test2/;
  let coords = result.split(",");
  let x = coords[0];
  let y = coords[1];
  let content = {
Trying to better understand the parent Trigger...
╰─❯ osascript -e 'tell application "BetterTouchTool" to get_trigger "7EC4DE89-EB50-4F31-9C05-FF05E37606BB"' | jq
  "BTTActionCategory": 0,
  "BTTLastUpdatedAt": 1738836527.776166,
  "BTTTriggerType": 773,
  "BTTTriggerTypeDescription": "Standard Item",
  "BTTTriggerParentUUID": "46BD2737-5241-497B-B504-546D59BA2645",
  "BTTTriggerClass": "BTTTriggerTypeFloatingMenu",
  "BTTUUID": "7EC4DE89-EB50-4F31-9C05-FF05E37606BB",
  "BTTAdditionalConfiguration": "Menu Item: no-name-7EC4DE8",
  "BTTEnabled": 1,
  "BTTOrder": 0,
  "BTTTriggerName": "Menu Item: no-name-7EC4DE8",
  "BTTMenuConfig": {
      "BTTScriptType": 3,
      "BTTAppleScriptString": "async function itemScript(itemUUID) {\n  let shellScript = `/opt/homebrew/bin/cliclick p`;\n\n  let shellScriptWrapper = {\n    script: shellScript, // mandatory\n    launchPath: \"/bin/bash\", //optional - default is /bin/bash\n    parameters: \"-c\", // optional - default is -c. If you use multiple parameters please separate them by ;; e.g. -c;;date\n    environmentVariables: \"\", //optional e.g. VAR1=/test/;VAR2=/test2/;\n  };\n\n  // this will execute the Apple Script and store the result in the result variable.\n  let result = await runShellScript(shellScriptWrapper);\n  let coords = result.split(\",\");\n  let x = coords[0];\n  let y = coords[1];\n  let content = {\n    BTTMenuItemText: `${x}, ${y}`,\n  };\n  return JSON.stringify(content);\n}\n",
  "BTTMenuAvailability": 0,
  "BTTMenuName": "no-name-7EC4DE8",
  "BTTGestureNotes": "Standard Item"
osascript -e 'tell application "BetterTouchTool" to get_trigger "46BD2737-5241-497B-B504-546D59BA2645"' | jq
  "BTTLastUpdatedAt": 1738895611.489466,
  "BTTTriggerType": 767,
  "BTTTriggerTypeDescriptionReadOnly": "Floating Menu",
  "BTTUUID": "46BD2737-5241-497B-B504-546D59BA2645",
  "BTTAdditionalConfiguration": "Floating Menu: mouse_coords",
  "BTTEnabled": 0,
  "BTTOrder": 0,
  "BTTTriggerName": "Floating Menu: mouse_coords",
  "BTTMenuItems": [
      "BTTEnabled": 1,
      "BTTOrder": 0,
      "BTTMenuConfig": {
          "BTTScriptType": 3,
  "BTTFloatingMenuRenderedPreview": "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",
  "BTTMenuConfig": {
    "BTTMenuVerticalSpacing": 5,
    "BTTMenuHorizontalSpacing": 5,
    "BTTMenuItemBackgroundColor": "168.213, 183.731, 225.311, 29.612",
    "BTTMenuFrameHeight": 300,
    "BTTMenuWindowLevel": 3,
    "BTTMenuOpacityActive": 1,
    "BTTMenuFrameWidth": 220,
    "BTTMenuItemBlurredBackground": 1,
    "BTTMenuSelectedTab": 0,
    "BTTMenuItemPaddingLeft": 10,
    "BTTMenuCategoryMenuVisibility": 1,
    "BTTMenuItemPaddingTop": 5,
    "BTTMenuItemBorderWidth": 2,
    "BTTMenuCategoryShadow": 0,
    "BTTMenuOpacityInactive": 1,
    "BTTMenuCategoryOnlyShowIf": 0,
    "BTTMenuItemCornerRadius": 10,
    "BTTMenuCategoryModifiers": 0,
    "BTTMenuItemBorderColorHover": "0.000, 0.000, 0.000, 0.000",
    "BTTMenuShowIfWindowLevelEqualsEnabled": 0,
    "BTTLastChangeUUID": "0A2FA459-B0EB-405A-8375-4680A0855400",
    "BTTMenuItemBorderColor": "0.000, 0.000, 0.000, 0.000",
    "BTTMenuCategorySize": 0,
    "BTTMenuItemsUseModifierModes": false,
    "BTTMenuElementIdentifier": "mouse_coords",
    "BTTMenuItemPaddingRight": 10,
    "BTTMenuCategorySpacing": 0,
    "BTTMenuItemShadowEnabled": 0,
    "BTTMenuItemPaddingBottom": 5,
    "BTTMenuVisibility": 0,
    "BTTMenuWindowResizable": 1,
    "BTTMenuCategoryResizeOnHover": 0,
    "BTTMenuCategoryBorder": 0,
    "BTTMenuCategoryPosition": 0,
    "BTTMenuCategoryZIndex": 0,
    "BTTMenuCloseAfterAction": 0,
  "BTTMenuName": "mouse_coords"
I can't find the "mouse_coords" menu anywhere :frowning:
  • Device: MacBook Pro (14-inch, 2021)
  • macOS: 15.4 (24E248)
  • BTT Version: 5.304 (2025040803)
  • Alpha: 0 update(s) behind latest Alpha version 5.304 (2025040803).
  • Regular: Installed version is ahead of latest Regular version 5.140.
thanks for all the details.
So 46BD2737-5241-497B-B504-546D59BA2645 seems to be your menu which contains the item that runs the clickclick script.
Does this Apple Script
tell application "BetterTouchTool" to reveal_element_in_ui "46BD2737-5241-497B-B504-546D59BA2645"
show anything in BTT's UI?
I think your details contain everything I need to debug this, so you could try to just delete it:
tell application "BetterTouchTool" to delete_trigger "46BD2737-5241-497B-B504-546D59BA2645"
Thanks for looking into this.
Running osascript -e 'tell application "BetterTouchTool" to reveal_element_in_ui "46BD2737-5241-497B-B504-546D59BA2645"' activates BTT but doesn't reveal the mouse_coords menu, instead it reveals a different Floating Menu (the top most one).
I then ran osascript -e 'tell application "BetterTouchTool" to delete_trigger "46BD2737-5241-497B-B504-546D59BA2645"' which outputted deleted.
I restarted BTT and I still see the phantom temporary variables. I also restarted my Mac and the issue persists.
Here's exactly what I see for the BTT variables after restart:
Persistent Variables
No Persistent Variables Set
Temporary Variables
BTTActiveWindowNumber: 331
OutputVolume: -1
focused_screen_height: 982
focused_screen_window_coordinates_y: 0
BuiltInDisplayBrightness: -1
BTTLastTriggeredAction: 388
mouse_screen_x: 0
fm_B_menu_item_hovered: btt-undefined
BTTLastTriggeredTrigger: Please Select a Trigger
mouse_screen_height: 982
fm_B_hovered: btt-undefined
BTT_OPENED_URL: https://folivora.ai
BTTActiveWindowTitle: BetterTouchTool Settings
fm_A_menu_item_hovered: btt-undefined
BTTActiveAppBundleIdentifier: com.hegenberg.BetterTouchTool
focused_screen_x: 0
fm_A_hovered: btt-undefined
mouse_screen_window_coordinates_y: 0
focused_screen_y: 0
mouse_screen_width: 1512
The phantom BTT variables are:
  • focused_screen_height
  • focused_screen_window_coordinates_y
  • mouse_screen_x
  • fm_B_menu_item_hovered
  • mouse_screen_height
  • fm_B_hovered
  • fm_B_hovered
  • fm_A_menu_item_hovered
  • focused_screen_x
  • fm_A_hovered
  • mouse_screen_window_coordinates_y
  • focused_screen_y
  • mouse_screen_width
Hold on, I just found something...
sqlite3 -json "btt_data_store.version_5_304_build_2025040803" "SELECT * FROM ZBTTBASEENTITY" | grep fm_B | jq
  "Z_PK": 30372,
  "Z_ENT": 9,
  "Z_OPT": 112,
  "ZBUILTIN": null,
  "ZDISPLAYID": null,
  "ZMODEL": null,
  "ZVENDOR": null,
  "ZINVISIBLE": null,
  "ZNEEDSALT": null,
  "ZNEEDSCMD": null,
  "ZNEEDSCTRL": null,
  "ZNEEDSFN": null,
  "ZROUNDNESS": null,
  "ZACTION": 366,
  "ZDISPLAYORDER": 0,
  "ZENABLEDNEW": 1,
  "ZGESTURETYPE": 767,
  "ZISENABLED": 1,
  "ZISTOUCHPAD": 21,
  "ZKEYCODE": -1,
  "ZLOCKED": 0,
  "ZMERGE": 0,
  "ZMODIFIERMODE": 0,
  "ZNOTESINSTEAD": 0,
  "ZNUMBER1": 0,
  "ZORDER": 1,
  "ZBELONGSTOPRESET2": 30298,
  "ZPARENT": null,
  "ZTRAIT": null,
  "ZCODE": null,
  "ZDOWN": null,
  "ZREQUIRED": null,
  "ZKEYCOUNT": null,
  "ZACTIVATED": null,
  "ZORDER1": null,
  "ZACTION1": null,
  "ZKEYCODE1": null,
  "ZMODIFIER": null,
  "ZORDER2": null,
  "ZICONWIDTH": null,
  "ZNUMBER11": null,
  "ZNUMBER2": null,
  "ZNUMBER4": null,
  "ZNUMBER5": null,
  "ZONLYICON": null,
  "ZSHOWHUD": null,
  "ZREPEATRATE": 0.0,
  "ZDOWNTIME": null,
  "ZTIME": null,
  "ZAFTERTIME": null,
  "ZNUMBER3": null,
  "ZUNIQUEIDENTIFIER": "68267A63-14FF-4F0E-A127-1F6DB84A967D",
  "ZNAME": null,
  "ZCUSTOM1": null,
  "ZCUSTOM2": null,
  "ZUUID": null,
  "ZCUSTOM11": null,
  "ZCUSTOM21": null,
  "ZCUSTOM3": null,
  "ZNAME1": null,
  "ZNAME2": null,
  "ZOTHER": null,
  "ZADDITIONALSTRING": "fm_B",
  "ZDESC": null,
  "ZGESTURECONFIG": null,
  "ZNOTES": null,
  "ZSHORTCUT": "-1",
  "ZCHARACTER": null,
  "ZMETA": null,
  "ZCOLOR": null,
  "ZNAME3": null,
  "ZSHORTCUT1": null,
  "ZCOLOR2": null,
  "ZCOMERSSI": null,
  "ZHUDTEXT": null,
  "ZJSON": null,
  "ZLEAVERSSI": null,
  "ZMESSAGE": null,
  "ZREGEX": null,
  "ZTRAIT1": null,
  "ZLABEL": null,
  "ZICONDATA": null,
  "ZCONTENT": null,
  "ZICONDATA1": null,
  "ZICONDATA2": "\u0001�PNG\r\n\u001a\n\u0000\u0000\u0000\rIHDR\u0000\u0000\u0001�\u0000\u0000\u0000G\u0010\u0006\u0000\u0000\u0000ycͬ\u0000\u0000\fNiCCPICC Profile\u0000\u0000H��W\u0007XS�\u0016�[R!\u0004\bD@J�M\u0010�\u0012@J\b-� *!\t\u0010J�\tAŎ.��Z\u0011\u0011,+�\n��\u0001\u0011\u001b�+�bw-�\u0005��uq]�ʛ\u0010@�}�{�}s�����sg�\u0003\u0000��/�梚\u0000�I�e������),R7P\u0003D@\u0005���/�K9���\u0000������M�(�k\u000eJ�\u007f��ע%\u0014�\u0005\u0000 �\u0010�\u000b�<�\u000f\u0003��\b��|\u0000�Rț�ʗ*q\u0019�:2� �5J���-J���W\u0006m�c�\u0010?\u0001�����2\u0001��<�@�\tu�0Z�$\u0011�%\u0010�A쓗7C\b�\"�m�\r����g�\u007f���7��\u0011M>?s\u0004�b\u0019,�\u0000�\\�˟�\u007f��\u007f��\\��\u001cְ�g�Bb�1ü=ə\u0011���\u0010���GFA�\r\u0000�����J��R�$��Q\u001b��\u000bs\u0006�\u0010O�����X!? \fbC�3$���C6E\u0019� �\r�\u001fZ!���C�\u0007q�H\u001e\u00187dsJ6#vxޛ\u00192.g����\u0006}P�\u007fV�$pT��v��7��9\u0016f�'AL�8�@�\u0018\t�\u0006đ򜸰!���,n䰍L\u0011���\u0002b�H\u0012����3dA�C����ñc��ļ�!|5?+>D�+쉀?�?�\u0005�\u0013I8\t�:\"����X���@U�8Y$I�S�4�?V5\u0016���F\u000f�����`%o\u0006q�� nxlA>\\�*}�X�\u001f\u001d��\u0013���F�����p�\u0005\u0001�\u0005\u0014���\u0019 \u001b��{\u001b{ᝪ'\b�\fd\u0002\u0011p\u0018b�G$\r�H�5\u000e\u0014��!\u0012\u0001��8��^\u0011(���Q��\u0013�p��\u0003�\u0018�S�䀧\u0010�0�\u000b�\u0015�J�\u0011\u000f\u0012�\u0013Ȉ��\u0011\u001fV\u0001�!\u0017Ve����/\f\u00072�C�bxF\u0016}ؒ\u0018H\f �\u0010����\u0001�{����\u0007�3��=���bOxJ� <\"� t\u0012�L\u0017\u0017�Fy\u0019\u0001:�~�P~ҿ�\u000fn\u00055]q\u007f�\u001b�Ce��\u001b\u0000\u0007�\u0005���}�̮��\u000e���\nk���\"��\t\r�Q�((e\fŏb3z����눊2�_�G�k�H��#=���~�}!l�F[b�b����i�\"ւ5\u0002\u0016v\u0012k�ڰ�J<��\f����b\u0007�Ɂ:��̗'�̤ܩΩ�飪/_4;_�\u0019�3�sd�̬|\u0016\u0007~1D,�D�8�����\u0002����z���\u0019�� ̶/ܒ_\u0001�>900p�\u000b\u0017z\u0012�\u0003��p�\u000bgÆ�\u00165\u0000.\u001c\u0015(d\u0005*\u000eW^\b��A��O\u001f\u0018\u0003s`\u0003�q\u0006n�\u000b��@\u0010\n�@<H\u0006Ӡ�Yp���,0\u000f,\u0006Š\u0014�\u0006�A%�\n��\u001a�\u0017\u001c\u0004��\u0005�\u0006?�K�\n�\u0001����\u0005��>�\u001a|@\u0010���\u0010\u0006��� ��=⌰\u0011\u001f$\u0010\tGb�d$\r�D$�\u0002��,AJ��H%�\r�E\u000e G���E�\u0003��<Dz�?��(���:�\u0011j��G�(\u0007\rC�ѩh&:\u0013-D��+�\n�\u001a݃6���K�\r�\u0013}��c\u0000SØ�)怱1.\u0016��`\u0019�\f[��`�X5V�5��|\r��z�w8\u0011g�,�\u0001��\u0010<\u0001\u0017�3�\u0005�\n�\u0012��\u001b��5�!އ\u007f&�\b�\u0004{�'�G�L�$�\"\u0014\u0013�\t;\tG\b��^�\"�&\u0012�L�5�\u001d��db6q.q\u0005q3q\u001f�\u0014�����O\"��I�$oR\u0014�O�'\u0015�6���N����Ho�jd\u0013�39��B��������\u0013��g�\u000f\u0014M�%œ\u0012E\u0011R�PVQvP�)�)]�\u000fT-�5՛\u001aOͦ.�VP����������<�b��j��*���]P{��N][�N�����P_��K���\u001d�W4\u001a͊�GK���V�jigh\u000fho5\u0018\u001a�\u001a<\r��B�*�\u0006��\u001a/�\u0014�%�C�F/���\u000f�/�{5)�V�\\M��\u0002�*ͣ��4��\u0018Z\u0013����Vh�ֺ�խMҶ�\u000e�\u0016j/�ޮ}F�1\u0003c�3�\f\u0001c\tc\u0007�\u001c�K��c�����)�٫Ӯӧ��뢛�;[�J��n'\u0013cZ1y�\\�*�A�M��1Fc8cDc���\u001fsu�\u001b��z~z\"�\u0012�}z7����\u0003�s���7��7�\r�\fb\ff\u0019l18g�;Vg��X�ؒ�\u0007��b�\u001a�\u0019�\u001a�5�n�f�odl\u0014l$5�htƨטi�g�m\\f|¸DŽa�c\"6)39i�\u001bK��a�*XgY}���!�\n�m��\u001f̬�\u0012̊����7����3���[��,L,\",�Y�Y�bI�d[fYn�<o����*�j�U�U���5Ϻк���\r���f�M��u[�-�6�v��\u0015;���.ˮ��=j�f/��l�1�0�c�d\\��[\u000e�\u000e\u001c�\u0002�:���L�p�\"�F�\u0017�-Ƨ�_3����N�N�N;��NО\u0010:�hB�?��\u0005�U��'�&\u0006M\\8�i�K\u0017{\u0017��\u0016�ۮ\f�\b�e�������dn�n=�\u0016�i��o�u���\u0015�\u000b\u001e\u0004\u000f\u007f��\u001e-\u001e�<�<�=\u000fz�����۫{��$Ѥ\u001d�\u001e{�y�yw��|�|����5���V�>�3�\u0013���{Ʊ�ds�p^�;�������zr�sO\u0005`\u0001�\u0001%\u0001�ځ\t���\u000f�̂2����]��\u0006�\n!����\t��3�\tx���P����g�����*�\u001e�ۅ�›#ЈЈu\u0011�\"-#%��Q �\u0017�.�~�u���c1Ę蘪���\u0013b�Ş�c�M��\u001d�:�?~U��\u0004�\u0004EBk\"=15�6�MR@�ڤ���'ϟ|)� Y�ܔBJILٙ�?%p��)]���ũ7�ZO�=��4�i�ӎO�O�O?�FHKJ۝��\u001fů�����7��\t��\r��B?a��G�-Z+z�᝱6�;�;s]fO�oVyV��+�\u0014��\u000e�ޚ�&'*gW�@nR�<r^Z�Q��$Grv���3:���bi�Lϙ�g���d;�|��)_\u0007��)l\u0014�(\u001e\u0016�\u0014T\u0015���8��l�ْ�ms��,��0���\\���y��\u0016�{8�3\u007f�\u0002dA��օ�\u000b�.�Z\u0014��f1uq�⟋���\u0016��$iI�R����>�&���b�bY�e^˶~�\u007f+��}���\u001b�\u007f.\u0011��T�TZ^�q�`�O�M��⻁�\u0019+�W��ڲ��Z���\u001a�55k��\u0016�}�.b]C\u0019�������_,w)ߺ��A���\"��i����\u001b?VfUި�ڷ�p��Mo6\u000b7_�ⷥ~���ҭ�\u0017\u007f\u007f{[�j������\u0005۟�H�q�\u0007�\u000f�;\rv����K���&��l�{m�n�ݫ��:E]Ϟ�=W�\u0006�m�w�߶���t?د��ہ�\u00037\u000f�\u001dl=�>T\u007f���#�#%\rHÜ��Ƭ�Φ䦎��G[����\u001cs<��Ŵ����U'�'��\u00188Yx����T���ӏ[���=3����1g�υ���cЏg�sΟ��}���ţ?�\u007fj��v��͵��Ϯ?\u001fiwko��~��Ǖ�I\u001d'��^=}-�ڏ�y�/݈��q3���[��:o\u000bow�ɽ��_>�]t�p�����\u0007�\u000f�\u007f��u_�[��\u0001\u000f�\u001e�=��X���\u0013���]K�Ҟ�?3yV�����\u0013�s�)�u=�>��[����^ؼ8���\u001fm}���^�^\u000e�����]\u007f����\u001f���u��\u000foJ�꿭y�~w�}��g\u001ff}$}��d���s��{\u0003y\u0003\u0003R��?�+�\u0001��&\u0003�?w\u0001@K\u0006�\u0001ύ�)���`ATg�A\u0004�\u0013V�!\u0007�\u001b\u0000��>�\u0017���\u0002`�\u000e\u0000��>=\u0015�h\u001a\u0000�\u001e\u0000�8q�\u000e��\u0006ϝ�B�g��#?�祃\u007fSTgү�\u001e�\u0002��\u000b\u0018��\u000b�\"�\u0015�c�\u0000\u0000\u0000leXIfMM\u0000*\u0000\u0000\u0000\b\u0000\u0004\u0001\u001a\u0000\u0005\u0000\u0000\u0000\u0001\u0000\u0000\u0000>\u0001\u001b\u0000\u0005\u0000\u0000\u0000\u0001\u0000\u0000\u0000F\u0001(\u0000\u0003\u0000\u0000\u0000\u0001\u0000\u0002\u0000\u0000�i\u0000\u0004\u0000\u0000\u0000\u0001\u0000\u0000\u0000N\u0000\u0000\u0000\u0000\u0000\u0000\u0000�\u0000\u0000\u0000\u0001\u0000\u0000\u0000�\u0000\u0000\u0000\u0001\u0000\u0002�\u0002\u0000\u0004\u0000\u0000\u0000\u0001\u0000\u0000\u0001��\u0003\u0000\u0004\u0000\u0000\u0000\u0001\u0000\u0000\u0000G\u0000\u0000\u0000\u0000���&\u0000\u0000\u0000\tpHYs\u0000\u0000\u0016%\u0000\u0000\u0016%\u0001IR$�\u0000\u0000,�IDATx\u0001��\u0007|\u0014��\u0000�sf��\u0007� \t\t\f5tBﺂ�\u0000\u000bAA@�x+�\u0005Q�]\u0010\u0016\u0005+M�g��\b*\u0016\u0010�\u0002�\"\"RD��\u0000f �\u0010�{vw�~gB\u0016y\b6�\u0017����$�;wf�K���sϽ\u0000�ќ\u0000�y�λ�\u0000\u000b�\u0000\u000b�\u0000\u000b�\u0000\u000b�\u0000\u000b\\�\u0002�WO�O?q�3�Ɋf+�=q\r$�q�Go\t��ٌ�Q�`��V��U�T�o�_�s�!�+�\t��I��S�*s\u0002�Ӟ�`�\u0019��,�\u0002�\t�D\u0018���\u001e�{b��/���M2C�ݘk7�d�$�)9`\u001eL��`�r����v�\u001fY�\u0005X�\u0005X�\u0005X�w\u0004�\u001eh\u0010�\u000e�5(�׼n�%�䏃��\u0000���y���\u0000�Լ�C�����Vi�3�k����.�Psߠ}�����3�?��\u001b�\f��o��}!�?;��gPXՑ�K�+'����YCo䰞�\u001e5�<L���)�Q�d��m]b&�\u0013���P(Th\u0017�����\u0001�\u001c��]�\r^��VP�ub�8\u000b�\u0000\u0000^\u000fv\\���aߺ��\u000b ��9����O���lώ�ԕ�h�K�b\"t�V8�2\u0010\u0001(c9\u0016`\u0001\u0016`\u0001\u0016`\u0001\u0016�\u0003\u0002�`\u0006\u0019\u0014�\n\u0004\u0014\b'�\u0014���\u0001Wb-(�: U\u001c�^\u001e��\u0003\u0006�^G��u1E�\u001d�rb��p���?910���\u0011���#i��\u001a_`=��E\u001f����3\u0000\u0019D������ڭ���j\u007f}�'��̽��\u0010K�y��ɑV�L��erO\u00074�b�ms�\t⠻�0�\u00103: �\"�\u001cpB��;8���s�\u000b?�\u0002,p�����\u0014�\u0010\bn�6}�wK\u0005d����3�G8���w7?}\u0018�A�����\u0018�=词\u001b\u000b�\u0000\u000b�\u0000\u000b�\u0000\u000b���Gx(L\b\u0007\u0019��B�\u0001���eᦟuJ\u0016��CM�(`'��b���A9R6�7G|'����+���}0�����\u000f��C�Ϊ�Q|aD\u0012F��\u0011IP����\u0000䌌GQ����\u0016�c^��/Ų²$d��\u0005�9L�\u001b�\u0001�9\f�\u001d\u0010K'\u0018'�p�2\u001b�\u0014A����(�L����,�\u0004�!\u0006:����+���O֤�\u0012P=�׮/�֕;����C�����T�O�N�S�(��AY\u007f\t�wb\u0001\u0016`\u0001\u0016`��T�\bH$\nH\u00020�R�C��F�b\u0006#@I��JAP���\u0003�'�h�\"����9�n���\u0003��}��:��_�\\\u0019�_\u0005 U;P�R����Į/=�/�e�yzpӇ�`{�$K-;��\u000f��A�U\f&�rc\u0001\u0016��\u0002�\u0010IA?А�'��$��2׉�i����\t�m��>H�W�\u007f\u0010\r0\u001aGC��?!>\u0002\u000b�\u0000\u000b�\u0000\u000b��e#�ϘX�Dc3\u0012),\t�`E���n8^��\u001e\u0016k�\u0011_�\u001f��w�v��\u0015U.�xC����\u0006ܴ�MO�1nm*�~�����K��c���i𰇮��#WjE��n�Qt���O�[\u0016�\u001b\u0005�!�B\f�e��#ܶ~�\u0015�/E�5[��ht\u007f俵W�\u0000oW��\u0007�7�\u0018\u001f�\u0005X�\u0005X�\u0005X�\u001f/`A\u000b\u0005\u001e�t�F\f�4D\u0019xE>���\u0010\u0013�gc\"��v\\���6v�\u0016٣�C4\u001d�tLǴ_�0�X��\u0002��t\u007f�sHi�n\u001f����������F�s\u0005�p��\u0011c�\u001c\u001a$Q�QB5\u001d\u00014&�\u001b\u000b���L@,\u0013��m�.}(շ�B�\b�1�Q�\u000b����C��,�%�ᡏ��7�\u000f�\u0002,�\u0002,�\u0002����\u001a\u00113\r�*�ڑ�X\u000f��p�s��`z�y���&�\u001e�g\u000e�;0o[�SC��\u001f�PdQ�<\t�(+n^��=�T�o\u0019��E�\u001d!�����ʁ���/���\u0012\u0010��V}\u0004k�\\ᰡ�W�\u001a\u0006r�<آR\r�\u0006�\u0003����K��Sd\u0001\u0016`\u0001\u0016`�K_�C%�\u001a}�i\u0011>@\u001d�5�������\b}1zt�\u0017�.�_�.N\r��z�\t}\u001fվ?�7\f��\u0018&���:ra+M�ˍ\u0005X��\t<\n�D�pZ�X��\r�����خ5�ė�M<A�Dpc\u0001\u0016`\u0001\u0016`\u0001\u0016`��K��jC�&��Q�Ф@\u0006M��!�}��O\u0005 ���a��)Q7�\u0002䁖\u001f;9!\u0015T1٧��\u0003��\u0002,P}\u0004ķb\u0007�(��-G�6\u0007:�F���H\n�� �P��Z}Δτ\u0005X�\u0005X�\u0005X�\u0011(��\u0003��D\\\u00003�����f;��\u0002����T\u0000�!�\t��&��d�\t\u0010\u0010��tK��\u0002��\u0002,P�\u0005��X�\u0014h�\u000e��\u0001��\u0018��\u0010�\u001b.����j|�|j,�\u0002,�\u0002,�\u0002�\\\u0001��T3-?\u001e���ت�[��ޭ\u0011��/�T\u0000\"\u007f\"�n���\n���\u0018x�\u000e�S\u000f����\u0017�\u0005X��\u000bdW����c\u0001\u0016`\u0001\u0016`\u0001\u0016�<\u0004t���X�0Ũ\t1�\u0010�@2Z\"2�\u0017\u007f*\u00001\u007fh�\u0007�u\u0012���[0�쬬S�\n����e\u0001\u0016`\u0001\u0016`\u0001\u0016`\u0001\u0016`\u0001\u0016`��\u0015�h\u0018���zmZ�<Xމ\u0003�6<z�\u0000Dz\u0018ۛ��\u0012�fh\u0006�K.ډW0�]]~\u0001\u000b�\u0000\u000b�\u0000\u000b�\u0000\u000b�\u0000\u000b��\u007f\t�4\u0004˘\u0015�\u001e\u0006B��(9 \u0014�8��9�\u0001��C�\u0010�v�\u0013�e\u0001\u0016`\u0001\u0016`\u0001\u0016`\u0001\u0016`\u0001\u0016`��, QB\u0003i}�:`��=\u0012���\u0012�x)�QL+\u0019rc\u0001\u0016`\u0001\u0016`\u0001\u0016`\u0001\u0016`\u0001\u0016`�\u000b%࣌�~j!��e�/T��\u000f\u000b�\u0000\u000b�\u0000\u000b�\u0000\u000b�\u0000\u000b�\u0000\u000b���/\u0019��|\u0019?�\u0002,�\u0002,�\u0002,�\u0002,�\u0002,�\u0002�/`:�.�\\\u000f�\u007f�\u0007�PQ�<|\twPu|'�\b���\u0011�\u0015O}%��JZ�\u0004E�>��\u0001Φ��?w�����w��\u0005����u��b��ʕ��\u0001�?@ۭ�\u0000��_<-\u0002�N�o�wO����~,�\u0002,�\u0002,�\u0002,�\u0002����\u000f@rN\u0006\u0010�z�\u001d9\u001f\u001c\"Gܮ'���gAI\u001fɥmю{n�\u001c�A�N7�vi+~,\u000f\u0010�u��u�W�\u001d��%؛nu9\u00109��Ц\u0014�Q�&�\u0013Ӵ\u0011�*{�<�H��p�xX��@�\b���h3֒0\u0002��p\u0005�\u0007�|�\u0014n�,\u0014���b�%ܖ\u000f�ޠ\u0019�\":�d�qt���\u0014�pc\u0001\u0016`\u0001\u0016`\u0001\u0016`\u0001\u0016`�? p�\u0003\u0010鈴Jn+�5�b��fQ\u000f�Wӿ�V�^0� (�isU$x�*�k\u0002}��N\u000f\u0007��q˪�Q>�[J��G�W$Y7���T\u0011&��I��\u0003�tY�\u0004\u0005z�M�,YU22�.�cs�\u001f�\u000bߨ��&�������2<��\u007f\"@Pi!J\u0000\u0005+p�<]���<�6BS,-,1A�4��A�\u0019�ͥj��1�\u0013�\u0014�C�\u000ey��^;\u0005\"Ok�t\u001c#P��\u0002,�\u0002,�\u0002,�\u0002,�\u0002�\u0010�h\u0001�4N�U�\b��vE�eN���\u001b�m��\u001d�.��xi��6;�\n���\n�a1<\f��\u0002�\u00177���Za.>bR�<=�7\u001c�r�V\u000fz]\u0012\u0014��\u001a.뇱/V\u000e���\u0005j\u000e��\u0007��嵶��K�w�%�\u0000o�8\f=\u000b�\u0007|P\\����-`�>�]\bS�8\r��!�(\u000b�e�\\L\u0002{�֬�\u0007^\u000eq\u001e=xl������\u000f�I\u001c<:C��[dI�!��-��ׄ޷����\u001fY�\u0005X�\u0005X�\u0005X�\u0005X�J��\u0007 �Z�D�,5\u0017Τ���}�ZS)�(���t�K�P� 7\u0011*�\b�\bVӶ��F|�.�q�>�H�4u1=i}@w�'����'�éFd?�\b\u0003�\u001f܃߷�\u0010\b�|�>đ�\n\u0015P\u001f���1mC��\r�.t\u0005U���Ծ��\"C���\u0006'�PY\u0013�О�49���r��\u00130�2 ���!pJ�h�����\u001cߖ\u001a���\u0017\u001e\u0015k\u0000�r�_�\u001aes�d�7�\u001d6�����\u0018X�X҃�Ս�v1z\u000f�\u001b\u000b�\u0000\u000b�\u0000\u000b�\u0000\u000b�\u0000\u000b�&p�f���H��@\u001a!u�\"���&or�'���y�\f��c�G��@S�K7�˨B�j\bj�ֲ6�S��Ԩ��Â��;}׶�G�\u0014�lK��G�\u0006�gH1��q-.�8pWn���x�d�(f�j؏�۩\b[zU\u001a-/\u0002��]�3%\u000b�⥀ʭ���\u0005\u001c�ʌ�\u007f�S[���a<�J�t�][�^\u0013��R\n3m��ҋ�Qa�\u001f��~��\u0007#�a�\"��F�S���A�z\u0006�k懇�mZ�6x�^z�\u0007s����6�\u001a�몿�n��=s�Jl��N3�\u001cQ;\"�\u001aF\u0017;�\f�S��P`��H����'t��\u0014�x1\r�\u0017���\"�\u001c`S���=Q���c?��pV7\u0016>\u001f\u0016`\u0001\u0016`\u0001\u0016`\u0001\u0016`��!p�2 �\u0017: �f�w�\u0007j\u0016P+�U�\u0014o��^��sY��b\t<�=�\u000b��\u0016�[T�\u000f���\u0014�\u0006����uH�\u0012��v�V�\u001b�{�#���8\b3�[���{W�\u0013�)���Ќ���tc�\u0011֓B�C�IIr6ر\u001b��\bP�3Kⳟ5�'�s\u007fI{I��0\u001a_\u0005������i�#h_�\u0007�v(\u0010f}\u001a�;\u0014�\u0016AT������L@ٔ���\rL���򬂻Mv\u0001�$���\u001cm�c\u001b��\u0003�m\u0018V賛W��\u000b��F�H�=�s4䨚\u0017ɋ+�5\u0018����Fm6\u0016�-665��*ס�џ���7�����:�^\f\u0001�o��Iy��ڛ�4��\b8�.ź�HU삚b\u0014*\u0010�yR�P=뽹��M��{K��3�a]�R�\u001d�|\u001c���9\u0015�sc\u0001\u0016`\u0001\u0016`\u0001\u0016`\u0001\u0016`��\u0004�;\u0000��ao#��ר��c���a\u0007�]�l������{��.�V�\\��Y�\u0010�R2&nmL���C\u0019�\u0007�%>\u0006u��\u0007\u001b�+�t\u001et���1��Rc~X�meθ\u001b��ضN�s�Ҥ�_�\u0019���Ծ��(��U\f�W��f�\u001a���,S��o0�>$Ͼ���Ϭ����\u001b\u000f.\rrx�{cK�2�xH�\u0004\n@^��\u000f��G\u0016D�k4���rZ��}n�vZ;ZF\u0006�Ԕ��\u001e�k�Rӑ:?m�ua�����\u000b�7�E��D\f�,��5m�5G`j�s\u0011�=J�\u0017�7�5ɷ��2zI�1�\u000e�$�\b\u001fMS����\u001d_9d�4�j��\"�t\u001eO�t\u0011�v��<=\f�4T�P7r?���\u000eh�\u0016�:J��̏\u0007^�)u��y���jʂ#�͑5]>���\u0013E��\u0007pte�h��WDS�1\u0013�\u000f��ǖ�v��(�Ǎ\u0005X�\u0005X�\u0005X�\u0005X�\u0005�\u00108�\u0000\u0004���x�p��W<Z����\u001f�N��\u0016��.6�\u0015��iR��\b�\u001bq\f�-�\u0014xԀ��I{9�5�\u0001J�kyk��\u0019����k�I�]�W߫��Zkk��\u001f�*Y\u000fe+\u0007���7�\u0017U�E2ַ�EY\r�,��R�Y-�\n�����3\u001e?����\u0010'\u0015�w���\u0001��n��f�ZH5\u000e\u0003)#3�3�x��Q\u0018_,g��\u0014O|E�b��\u0004�\u000fx6�j�rx�:{ӑ��6N��-���Y��tC}'\f����\u0019����!��(��sv�ՑWR�G�\ft��b�\u001e�n�۲��݈\"�\"�H�^\r3\"�PDE候�\r��%5��uG\t\u0000��#v��Q�{��>�X���4I�kj/ \u007fl�[�qV��MO�B;��V0�\\l4�r\u0004\u0005fOZV\u0006��9��\bL���W�\u001bEW\nhT�\u0010\u000eS7��\u00177\u0016`\u0001\u0016`\u0001\u0016`\u0001\u0016`\u0001\u0016�\u000b�\u007f\u0000R����R�d~Z�mK,�C�>U\u007f^<�uC���_q��\u0014G��v3\u001d6\u0014B��\u0019��#�f�\u0002�[\u0003s5'|,\u0016�М6�n\f��s��^�I8)�ق�Q��n��^t��1.�^\u0001W���ٷZ�xP\t��ku�0�\u0010?�P���{M�Sk�=�=,��\u0001>%\u001f�\u001a�m��t\u000b�&�d�9*iod6��%�N�!��\u000e(Z�V�[\")�S�G�p`)fJ�\t���^C\u000b�pd�4G.�@*\u0013|�3R\u0000�������\u0017���\u00177G9�\u0018\u0018U��\\��g�����A\f\u0015c�����_o1�\u0004_\u0002gAQ�\u0019�mʑ\u0019���n\fU��z\u0010-��\rؖB7���}�^\b�\u000f\u0016\u001eʰY�#?������\u0015\n���\u001fB\u0015^���%\nXZ��4\u0014�\u0019�YtF�\u001d�PcZ�޸�\u0015.�m�vm\u0019�\u000e(\u0000������\u001b��g\u0001\u0016`\u0001\u0016`\u0001\u0016`��\\�\u0003\u00101Q��OGW���=b�+�ۢN�G$���\u000f��+\\$�w��i�qp��thyh~�Y�����\\�L\u001c�l)C8Zvn:��\u0007�]�C\u000b�|S�\b\b\u000fx%|��Q��,,\u007f�I�4hG��\n4�kq%��m��d\u0017��IkrW��t�)��Lw5|�����\u001c��+|S��r�\u001e�[�s�\u0000Wʂ��l~�2\u001b'��>U��c8\u001a��S`���x�\u0015m��\r:���Dl^���nes��y.y����n?2����\u001d�]�\u007f��Hn\u0012l�:a\u0003�\u0003\r![��R:*�W�ܞs��]��8��Q�\u0012QP3GYPA9\u001f\u0001�@�������\r�����=�Sv�\f�\u001fsed�Z\u001b�o`\u0016\\M9#��JF;N_�(�h,��;RИ%�\u0016��\u001b�b{�?��{�\u0010\u0011�κKc_�\u0010��Jx�匛���jp:J����%z?�\u000fN\u0016�\u001b]rc\u0001\u0016`\u0001\u0016`\u0001\u0016`\u0001\u0016`\u0001���\u0007 �O�<��ʋ-�#�Q��\u0006��9K\u0016�%�\u0015�@^*Ǚ��4\u0014J,\u0012u)��\u0012�b\u0006e@�����@\r�>��ګ<Ψ\u000f#ok�^��>���ςZ:�쥼�&���<Z#\u001d���S\u0016� ���U��=\u0019V�C�\u00157��\\w��\u0016\u000f�8�BE��h�={쌘��_/v\u0015�\u0016�\u001d����<�Uz *�M\u0019\u000e]6ֽ�DP�\u0006:�f�[\u0001�5G[l�{��L%jWd�F��9p2��g�\n]\u001b�D�T�R o���\u00176G���V�erBC��nt����idz�֗<���\u0002�\u000fE�j�W�#�\u00064\u0014��4�\u00071@��h\"^�\u0015ӝ�p�\u0011�K��\u0000�܈8m��\u0019�4\u007f\u0016@\u0007؂7P��5\\E�B�GC[��Y0�2W��r\u0007�\u0014\u0007:T%u���!�F���ߣ���\u0007(�B����b�����\u001b\u000b�\u0000\u000b�\u0000\u000b�\u0000\u000b�\u0000\u000b�& �����x��P2fQj ����\u0010W�^b\u0005: \u00152�j\f��\\9=,������iZ^/=~\u0017L\u0014���\b���\u001f���\u0014�*ڜ�9�@��\u0013�H|\n��\"\u001f������cߎn֦�\bp\u001e}F�\u0013�z��Dہn)Z�Lo\n%l}�1�ʁz1ӭ���K�\u0017��\u000b�\u001d>1�~�2\b{*��\n���_�����B���E\by0h\\��^W�؀]5�z��\"j�ף\u000b\u0002�+��w �-2��y�\u001b^�Mv��\u0002�r*��fML��Ds�[�Z�\u0007?惐\t�]�\u000eU���A�Q\u0003*��\r���n�P�K\u0002�D���\u0007���\u000e/�!�K\r���׮�L\u001a�6\u001d�1f'+m\\V�w���i̾Ϋ�j�S6\u001d���PE*�\r��4�\u001b\u000b�\u0000\u000b�\u0000\u000b�\u0000\u000b�\u0000\u000b�E�3 �ꓦ�\u0015\u0007�Q��V\u0018ፗV�\u001e��W��@.ͽ�L�怩j�\u001c��\u001d ̸�?K�\u000f�hzWE�-\u0005��;X\u000b�*�i/�N�S�KC��B\u001f�\u001a\u00050��bH���#Ӄ�\u001bu\u0015Z�z�~�O\f��E)8l\u000fZ{\u0005?�9�ò�l�\"�#�M�G�7�R�����3�J\u0013�: M�\u0010S+�\u0016?�k�\ne\u0004���W\u00054FF%\u0017��7�x\u0018�~\tt*\u007f�\u0006��Uz\u001e�Pnox��a��\\w�/\u001b��;%\u0017�l�[�\u0010\n���\u001d�\u0000���S�YV�,��gd�K�\u001b�읓��g�(�ba�����\u000ex�\u0006�5�i���^�x%889�⛨\b{�1?�\u001e^l7�l^\u0014�F�0�S-L�i\u0001��8�e\u0001\u0016`\u0001\u0016`\u0001\u0016`\u0001\u0016�,\u0005�\u0010��j>Z��\u0012\u001a�\u001b��c3���\f*���\u000b-m���\tr�Ӫ�O\u000f��A���f{z\u0019���h�)0\tJ(s���]�r���S\u001a��<��\u0019�T(�\u0002\n6.�v�rQ�@�P�/�\u0013`���˶P��z�Z�\u001e�\u001d�����Dھd\u001acݮ+A1A�j.�9\u001b?U���|{���K���s�^=ʷ\u0014�h��\u0013��>i:8J����Z�]�+\u000b�2�[��\bv�{��?\u0014>c\u0016`\u0001\u0016`\u0001\u0016`\u0001\u0016��\u0002�^\u0000򋇑[\u0001�\\V�Bj嗇�����I�_�p2$1���!d\u0014��q�K��2(�\f��E�ƒ\u0014p��3V�\u0010:#sU9�n�xZ��\u0005\u001e��\u000ei\u001c�C�\u0007\u001f����Es����J{��aT�f�\u001d�ݨ���\u001f~N��B���If'\"��{p^Z8|�,�\u0002,�\u0002,�\u0002,�\u0002\u0017[�Ҿ���:���s��?�2\u0016���ܒV��L\u001eozJ���<؜X�\u001dR�])�g~�~ϐW�U�j���|5@�*�y�Pi �\u001c���\u0015pc-Z_�)͊UH_\u0019��\\��\u0001�%\u001f���\u0015Z�~\u0011|\u0006�~#0�'��\u0000\u000b�\u0000\u000b�\u0000\u000b�\u0000\u000b�a��\u0007%�������J\\�m�UһdYv�\u00052;eM�\u001f\u001f�\u0012K�\r���\t��B\n��k�I���=�\u001b\\���d\u001c�Lڻ5\u0018Rk�߹31�)�`�<���Y��f!9L��4ەC�Y~��p��:��_4P1��z\u0017m4���rP��\u0012\u0014�Sf\u0001\u0016`\u0001\u0016`\u0001\u0016`\u0001\u0016�\b\u0002\u001c�\\\u0004��إT[:bzZ�j�1��?�}taz؏?�\u0001�\u0006S�a��+\u0018j`,e4�Y�\u0013ڵ7i\u00160\u0013�f�\u0012��\u0015Th�[1��LǿO�\u0007B��o\u0013�P�\u001bӒ�=\u0010�:�$'L(p��\u0006gDM��L\u0001zN�\u0010,ch\u00177\u0016`\u0001\u0016`\u0001\u0016`\u0001\u0016`\u0001\u0016 ��\u0017��P��\u007f�Ts@Ct�r�����\u001fj9PZY�PH��'h�ZU���\u0007��Q1��/Uh\b�8F;ۍn\u001a�r���S��\u000b��'��Z�4QRy\u001c���?����C\n����\"��^�lؔ��\u0005\u001c�]���]I���T�:\u001a\"Ek{T���]\nv���M\u0004Q�\u0011��)(q»b\u0003M��Ѐ��TRn�'�\u0001�pTi\u0011���vTb6^1��\u0005�\u0016����@���\u001e[\u0002���l���~n,�\u0002,�\u0002,�\u0002,�\u0002,�_\u0002\u0017/\u0000��O˛�b|O�|�����\"<\r$�[�\u0013r/Z�|�t��\u0010�\u0017>F4\u00147�'�\u0011��,��*�����g�@цj���H.ߝ�7��\u0014}\u0018��Ԡe=vhw����\u0010\u000bi�\"�(�\u0000��Ӯ-\u0012#�\u0016\u0018D_1B<�Nm���yYr�\u000bE��B��\u000fҒ}�%к��1Th������\u001f�����G�:��Þv�S��%S?\u001a���H����DH\u0014^�q\u007f\u001f&BS:\u001f���olx'��o��u�zy�%��\u001a]�Ւ��ha�zt�F\u0000h���7��S�6��ә�XL�}�޻��\u000e�K�W>d�RWL��^��:\u0004J�]j,�@��:�wh^`�W'�]�w\u000bݖ',\u000b��kv\u0011&��I��\u000b7\u0016`\u0001\u0016`\u0001\u0016`\u0001\u0016`\u0001\u00168��\u0005\u000f@D\u0018t\u0017t\u0003jAKY@�fo�mڥ��Yj�ʊNŏ�v\\��hb['��\u0013X\u001b�!��%�&z@|',�mH7��A��\u001e�g\u0007?\u001d%{�m��O\u000e�3CՖ��|s�A�\u0010`\\�\t��\u0016UW��MK��S�,���`�\u001b�m4�,�\u0003��ZGt�Y\\;���X5o7����\u0006�\u001c\u0016bkp����uC¾\u000b}.�v�\u0002�i�o7(�3c�t:\u0000�\u0003�v�·��6᎗\u001b�ꕔ�k\u001eS'��B\u0015-�X\n��@sʭ�\u0005�\u0015c�>�O,u�lP͵\u0017P�x̓^�\fD�������&}+8\u0002��^\u000f��Ԅ�-`@�\fE[���mI^\u0003`*\u0005r�?|\u0006��1:H\u0001�u���98-��c\u0002�j\u000ek��v�FM\rk\u0010�<�\n�m�펐�4# L��v\u0010��\u0012} \u0007\u001e\u007fؙ_�\u0002,�\u0002,�\u0002,�\u0002����\u000f@&�I�\u001f-\u0014X$55\u001f\u0013��z\\��eE\u000e\u0018\u000e\u0013�%�1\b����\u0001#i�\u000f��n\\��_E�XL+u��P\u001f�H1\u000f����'x��6\u001c[�w���\u0019���ъ+�o�7�k�AX�o�>�\u001b}#�\u0000��9�V�I<�\u0010�w\fK�ө�Uc]��8o�\u0002\u001a�\u001aIt�ܙ�kFǿ_| �P���j\u0016ZюU��\u001a[Z�P��TFfD��\u001d�}�NjU\n�&c�pW��\r}?A����\u0012�Y�I+�/գ<\u0015\b�f��e\u000fI\u000e�A���q����0�\u0001�\u0007�\u0012m\u001e\u001ePCw���t[k����������O$eb(\u0005E��g\u001a��Pn\u0004h�\u0000�E��M���\u000b\u0014�\u001d���]���0B�\u0006�X#6ђ�\n�L� Ɩ\u001b\u000b�\u0000\u000b�\u0000\u000b�\u0000\u000b�\u0000\u000b�\u0001�\u000b\u001e��P�����n��O�\u0014=�n�#�N�:��V�^y\u0003k���F�\u0004F&B�~���ݕ�Ѡ�_\u001a�CaT~�\f<:��\u0006�2\u0004#D\u0001\u0005\u001c�D\u0007�~���\f)\u0014N8�\u0000�%F\r�9�QT-Z�\u0003#�|\u0001��V�X%�\u0013���Y��� �η��?���\u000b�E�/\u001c��V�n�q�?��~L�݈J���3�>�eW��uu�R��v����_{����/wV9\u001b+�����<\u001b�T��\u0014xP�\u00077\u0016`\u0001\u0016`\u0001\u0016`\u0001\u0016`\u0001\u0016�S\u0002�?���b�L\u0018\u0001�Xs���+���kh��\u007f¾�ׯ=�#U�\u0010���Y?�?@{�F�q��߹\u000e\u001c\u0003c�\"��>0��Nԝ!���j=V\u0001�\u001d\u007fƷ��T?��C\u0019U��S�e�X�'����:3�)\u001a\n5\u001b֊�Tf�\u0006j�k�\u001d���ß��G���\u0001x\u0007\u0016`\u0001\u0016`\u0001\u0016`\u0001\u0016`��I��\u0007 ���>�2\u000f��\u00159���#�]5��\u007fs��t;e\u000b\"h�)�\u0005g��f\u0004NrS�l~J�t���6\u001c�SC�.�\u0001�C\u0016`\u0001\u0016`\u0001\u0016`\u0001\u0016`\u0001\u00168\u007f\u0001\u000e@���d\u000fU�\u0016|\n'Io\t������\u001e�yɽP\u00078K?�)\u0013����\r\u0007'\u0007\u001eg��X�\u0005X�\u0005X�\u0005X�\u0005��\u0000\u0007 \u0017�-9}ȗQ�r��1���F]le�\u0005X�\u0005X�\u0005X�\u0005X�\u0002\t�\\\u001b�\u0002u�ݰ\u0000\u000b�\u0000\u000b�\u0000\u000b�\u0000\u000b�\u0000\u000b��o\tp\u0000�[:�\u001c\u000b�\u0000\u000b�\u0000\u000b�\u0000\u000b�\u0000\u000b��\u0005\u0015�\u0000�rrg,�\u0002,�\u0002,�\u0002,�\u0002,�\u0002�%�\u0001�o��s,p�\b4�\u0018Z��I�k@\u0017\b�TN�ϓ\u0005X�\u0005X�\u0005X��\u0013�\u0000��{����A\u0002�\u0014��\u001b8�\u001c񌯓W\u0015\u0019�VO\u0013@�?\u0007A#\u000eD�Ao5_\n\u000b�\u0000\u000b�\u0000\u000b�c\u00048\u0000�Ǽ�|!���x\u001c������.-��wi��ទ�\u000b:A'����҄/�\u0005X�\u0005X�\u0005X�Z\u000bp\u0000R��\u001e>9\u0016�m\u0001�\t�`+�U��«\u000b��ڽ\u0015�47^\t-�a�����,\u000b�\u0000\u000b�\u0000\u000b�\u0000\u000b��\u0002�\u000e��o�Gd��\u0017�Kk�\\\u000bv�\u0018�ӏhPZV^��\u000f�N�N��]�'����:TV*\u000f\u0014}���\u001eX�\u0005X�\u0005X�\u0005X�B\t�ʀ�g��4Q�}�'>�*x�\u0003\u0005�^�\u0003q?,�\u0002\u0017@ �d\u001f�6>&u��+|Y�C�\\Ymr\u001b�\u0019�6UZ Ś#�q`C\u001bU�pc\u0001\u0016`\u0001\u0016`\u0001\u0016`�j'p*\u0000I�>q�V��;|\u0003���ϕ8�A\u001c���vg�'�\u0002��@wh�#�)ƈw�����WyE���\u0003�\u001d�\tœ<\n���H\u000b�}9\u0013�\u0000\u000b�\u0000\u000b�\u0000\u000bT\u0013\u0001\u0019$@�\u0014�6\"}8:�\u007fV�\u0002��\u0001��_�\u007f\f�?������C��װ\u0018T��w���Y9#�7�-\u000b�}\u0002F�#���A�����l|W*��`c��c\u000f:�n��y��r_)�ԟ����\u0004� ��;A>\u0012\u000b�\u0000\u000b�\u0000\u000b�\u0000\u000b�! �\u0011z��\u0001�q�\"\\�\"r�\\o��U�\u0002\u0010�Xn\u001apO��i�ǧ\u007f��T�DLn���\u007ft�c�4-�\u0007���J�d7�\u0002\u0005����\u0001oY�\u0005.�@8D@Kt�&|Qz�2��0\u0002��ZE\u001dRV$�)�\u001ck�e�\u001fWBk��(��x\u001c��p꓅�pF�%\u000b�\u0000\u000b�\u0000\u000b�\u0000\u000b�1\u0001#�a����\u0014�}\t�dX Z��w>U�.��(�:Dž�Agi��Xʶ\f�W��\u001d)m[1���<�^\u00189�c�v�X�kA\u0005a��\u001b�7-�8�XxUd�vx\u0006�\u0014e�C,\u0013��m�N�O�X�\u0005�%���Na\u0006\r���8\n�J��Y�,�\u0012u�\u0006}�����=V\u0016W�Ⱦ-?qo׽걘�1�{\u001d����\u007f\u0002\u001d�\u0016\u001e���p�{p��\\��8\u000b�\u0000\u000b�\u0000\u000b���+`�?�4�*\u001e�@��\u0005�'�j�B'�q\"�\u0002\u0010ߏ���9OXn����i�\r��\u0016늬\u001e����2���5HJ�Z\u0011�z�A�V׮\u0017�\u00164���(�\u001an~$tM�j��\u0012\u0011����t�<ź<@�\u001c\u0004�\u0011.� �X�\u0005�\u0010hFk�wG��\u001e�\r�P<�x^.�(�]1�[�ps������\u0013�r�,_n��S���,�>P��%EI\u001f��Jsp\u0012��@pr�q�+��\u0002,�\u0002,�\u0002,�\u0017�@\u0005\u0014�ǥE\"\u0017�i._���<?G�\u0018�\u007f�o����ƎS\u0013wb\u000e~���t���1�\u0012`��-��[k���\u0019�%›�H��+�Qr[[\rS���<. �䔺K[L#展7FG��,�\u0002�\tԡ\u001cᕨ\b�8����{|S�[z\u001d�X�T�L��E\"��U\u0007�g�6�<ʌ��3������t�p��i��#\u000b�\u0000\u000b�\u0000\u000b�@u\u0011��\u0005\u0004ݧX�\u0006$Ĥ�\bq��ǹ��=��MY��?�S\u0019\u0010�\u0003p\u0015ԃ�\u0003M�uJ��Z\u0001����p9�\u0004ք�\u0001�M\u0006�\u007f�|�%R�\u0002\b�\u000e�n�=�[{G\u007f��C\u0005�\u00168\b�`\u0000�̈}���\u007f`\u0001\u0016�E ��@u�;y\u001c��>�\u0017��L\u0000�-�%'�K�p�u�l��Nw2��eG��\u0005X�\u0005X�\u0005X�\u0005�����\u000f\u0001\u000e��0��\u0004��2�x�̳�g@�[\u0011W��_���1d����Э��1���\u001a��r\nC�}\nղk\u0014�(gvĿ�\u0000\u000b�\u0000\u000b�\u0000\u000b�\u0000\u000b�\u0000\u000b\\�\u0002F�B��\u0003m�j0e>\u000e�{ŴÉE���g�?>5p�\u0017���D�\f��b�Fs\u00136&l�(�\u000b�\u0002=\u0004\u001f^?\u0007�\u0010\u0005b}���\u000f\u001dB${e\u0000b�V��\u0000\u000b�\u0000\u000b�\u0000\u000b�\u0000\u000b�\u0000\u000b\\�\u0002Fbˆ\u000b�qBU��#�q�?Ψ�\u0012���9�I-�t�k�\u000e��O�[�!\u0004X\u0014(�!VE��3\"��'X�\u0005X�\u0005X�\u0005X�\u0005X�'��x�Аr#A�8\fe\u001eUO�v\"o��_ߓ�-u��\\\u0017�π�z^��Uv�\u0004JU�w��@{Q��\u0006_�l��\"\u00014Q\u000eV*!1\u000b\u001f�F\u0012��'�N�;�\u0005X�\u0005X�\u0005X�\u0005X�\u0005X��\u0017�������q@U\\�\u0013�q���ό+���*\u0000Qi��\u001b��Na���iz�W�9���Ǵp}\f6Z�G�[��d;\b��\u0000S��ڝ�C�\u0000��B\u0018\u000b�p\u000e�dL�H\"�\f;�\"��ȼe\u0001\u0016`\u0001\u0016`\u0001\u0016`\u0001\u0016`\u0001\u0016��\u000b��������x�}}լV��~\u007f\u001c�\u000b�q��B�q�?��?����\u0010,\u007f�rf\u0007��n�&�9N\u000b���j\u001e\u001a\u007f\u0003,���ʛ���`\u0011�l�ZX\u0007T�\u0001I\"\u0007d�\u001b�(\f��ms�@\u0010\u001d�K����\u001dn,�\u0002,�\u0002,�\u0002,�\u0002,�\u0002\u007f���\u0016����}�\u0003%T#�Js����\u0005\u0004#h\u0001A;d�4P4�\u0018\f�E���p;t\u0006ہ��\t���eI��-�i��}b����\u00157���o\u007f7\u0000�п�\u0017�\u001cz`gϝ=��q��qLs�K��!���\u0006ﰈ�ĝ�\u001e���Vz\nơ\u001a���` �۬�\u0011*Y)\u0010s���\u0005X�\u0005X�\u0005X�\u0005X�\u0005X�o\u0014�\u0007\ba8N�*J�B��O�9B�\t�7a�x+��/E���NΌ�����7\u0017�j:�ߋ\u000b.֕��\u0000�b�\b��\u0002,�\u0002,�\u0002,�\u0002,�\u0002,�\t��8��\u0001�\u0018�/�P�\u0000\u0000\u0000\u0000IEND�B`�",
  "ZICONDATA3": "\u0001{\"BTTMenuVerticalSpacing\":0,\"BTTMenuHorizontalSpacing\":0,\"BTTMenuItemBackgroundColor\":\"168.213, 183.731, 225.311, 29.612\",\"BTTMenuFrameHeight\":100,\"BTTMenuTextMinimumScaleFactor\":0.29999999999999999,\"BTTMenuWindowLevel\":3,\"BTTMenuCategoryItemVisibility\":0,\"BTTMenuItemBackgroundType\":4,\"BTTMenuFrameWidth\":350,\"BTTMenuItemBlurredBackground\":1,\"BTTMenuSelectedTab\":0,\"BTTMenuItemPaddingLeft\":0,\"BTTMenuCategoryMenuVisibility\":0,\"BTTMenuCategoryItemIcon\":0,\"BTTMenuItemBorderWidth\":2,\"BTTMenuCategoryShadow\":0,\"BTTMenuItemPaddingTop\":0,\"BTTMenuCategoryItemBehavior\":0,\"BTTMenuCategoryOnlyShowIf\":0,\"BTTMenuItemCornerRadius\":10,\"BTTLastChangeUUID\":\"29870689-B9D5-4DC2-9189-4E1BF19D05A6\",\"BTTMenuItemBorderColorHover\":\"0.000, 0.000, 0.000, 0.000\",\"BTTMenuCategoryModifiers\":0,\"BTTMenuShowIfWindowLevelEqualsEnabled\":0,\"BTTMenuCategoryItemSpacing\":0,\"BTTMenuItemBorderColor\":\"0.000, 0.000, 0.000, 0.000\",\"BTTMenuCategorySize\":1,\"BTTMenuItemsUseModifierModes\":false,\"BTTMenuElementIdentifier\":\"fm_B\",\"BTTMenuItemPaddingRight\":0,\"BTTMenuCategorySpacing\":0,\"BTTMenuItemShadowEnabled\":0,\"BTTMenuAppearanceStyle\":0,\"BTTMenuItemPaddingBottom\":0,\"BTTMenuAlwaysUseLightMode\":1,\"BTTMenuCategoryBackground\":0,\"BTTMenuCategoryItemSizing\":0,\"BTTMenuWindowResizable\":1,\"BTTMenuCategoryResizeOnHover\":0,\"BTTMenuCategoryBorder\":0,\"BTTMenuCategoryPosition\":0,\"BTTMenuCategoryZIndex\":0,\"BTTMenuCloseAfterAction\":0}",
  "ZBEZIERPATH": null,
  "ZHUDIMAGE": null,
  "ZHIDDEN": null,
  "ZTOUCHBARMODIFIERUNHIDE": null,
  "ZDISABLEDRAWINGS": null,
  "ZDISABLEMIDI": null,
  "ZUPDATEDAT": 754179859.6272219419,
  "ZNOTCHBARMODE": null,
  "ZNOTCHBARMODIFIERUNHIDE": null,
  "ZDISABLEGLOBALTRIGGERS": null,
  "ZDISABLEGLOBALTRIGGERS1": null,
  "ZCONDITIONS": null,
  "ZDISPLAYNAME": null,
  "ZDISPLAYUUID": null,
  "ZHUDSFSYMBOL": null,
  "ZACTIONNUMBER": 0.0,
  "ZMINIMUMDOWNTIME": null,
  "ZACTIONDATA2": null,
  "ZACTIONLABEL": null,
  "ZEXCLUDE": null,
  "ZCHEATSHEETCONFIG": null,
  "ZUSECUSTOMTRIGGERLABEL": null,
  "ZSTYLEDATA": null,
  "ZCHEATSHEETFORMOPEN": null,
  "ZUSECUSTOMACTIONLABEL": null,
  "ZTRIGGERLABEL": null,
  "ZLASTUSED": 754182007.1726909875,
  "ZACTIONCATEGORY": 0,
  "ZALLOWCONTINUEDTIME": 0.0
Here's my latest troubleshooting. Would appreciate your help Andreas.
Output:
250408_22_13_59_fm_B_occurances.txt (193.0 KB)
I wrote this Python script to pretty print the ZUNIQUEIDENTIFIERs found in the above output.
~/projects/BTT/troubleshooting/btt_uuids.txt
0FCF046D-479A-4260-B8D3-A8066506B96C
F623CB5B-E30E-41F2-A5CB-5ECAB4D4B21F
5CEC199D-B062-4EF0-AB5F-FB6754C02032
D922EC85-C539-43F9-9AAB-B01D1BCF0063
0C8EC140-40C2-4668-9D48-0A0AEC35C13E
E778E864-0CED-463F-8B96-44BC7A343833
E3C7B3B5-0BF3-4678-8DAC-E82DF1E1B62A
C18D2D13-73D3-4A0C-8F0F-D55279F8EA7D
F97BBC1E-54C0-488D-8C84-F5B8F688AFCB
C481ABCE-C455-4524-B991-3DC68530B5B5
CB9C8D62-1205-4378-A96A-BFB2D838057A
#!/usr/bin/env python3
import sqlite3
import subprocess
from pathlib import Path
from typing import Dict, List, Optional
from rich import inspect, pretty
from rich.console import Console
from rich.traceback import install
# Rich setup
install(show_locals=True)
pretty.install()
console = Console(force_terminal=True, highlight=True)
# Configuration
BTT_DB_PATH = "/Users/jacob/projects/BTT/btt_data_store.version_5_304_build_2025040803"
UUIDS_FILE_PATH = "/Users/jacob/projects/BTT/troubleshooting/btt_uuids.txt"
OUTPUT_FILE_PATH = "/Users/jacob/projects/BTT/troubleshooting/btt_query_output.txt"
# Utility functions
def insp(arg) -> None:
    """Rich inspector utility for detailed object examination."""
    return inspect(arg, all=True, help=True)
# Database operations
def get_connection() -> sqlite3.Connection:
    """Get a database connection with Row factory enabled."""
    conn = sqlite3.connect(BTT_DB_PATH)
    conn.row_factory = sqlite3.Row
    return conn
def query_by_uuid(uuid: str) -> Optional[Dict]:
    """Query the database for a specific UUID and return results.
    Args:
        uuid: The BTT unique identifier to search
    Returns:
        Dictionary of results or None if not found
    conn = get_connection()
    cursor = conn.cursor()
    try:
        cursor.execute(
            "SELECT * FROM ZBTTBASEENTITY WHERE ZUNIQUEIDENTIFIER = ?;", (uuid,)
        result = cursor.fetchone()
        if result:
            return dict(result)
        return None
    finally:
        conn.close()
# File operations
def read_uuids_from_file(filepath: str) -> List[str]:
    """Read UUIDs from a file, one per line.
    Args:
        filepath: Path to the file containing UUIDs
    Returns:
        List of UUIDs as strings
    with open(filepath, "r") as f:
        uuids = [line.strip() for line in f if line.strip()]
    return uuids
# AppleScript operations
def get_btt_trigger_info(uuid: str) -> str:
    """Get trigger info from BTT via AppleScript.
    Args:
    Returns:
        JSON string with trigger information
    # Fix the AppleScript command to properly capture and format the JSON output
    applescript_cmd = f'''
    osascript -e 'tell application "BetterTouchTool" to get_trigger "{uuid}"' | jq
    try:
        result = subprocess.run(
            applescript_cmd,
            shell=True,
            capture_output=True,
            text=True,
            check=False,  # Don't throw exception on non-zero exit
        # Check if we got any output
        if result.stdout.strip():
            return result.stdout
        else:
            console.print(
                f"[yellow]Warning:[/yellow] No output from BTT for UUID {uuid}"
            if result.stderr:
                console.print(f"[red]Error:[/red] {result.stderr}")
            return "{}"
    except Exception as e:
        console.print(f"[red]Error executing AppleScript:[/red] {e}")
        return "{}"
# Display functions
def display_uuid_info(
    uuid: str, db_result: Optional[Dict], trigger_info: str, output_file=None
) -> None:
    """Display formatted information about a UUID.
    Args:
        db_result: Database query results
        trigger_info: AppleScript query results
        output_file: Optional file object to write output to
    output = f"[bold]UUID:[/bold] [yellow]{uuid}[/yellow]"
    console.print(output)
    if output_file:
        print(output, file=output_file)
    if db_result:
        console.print(db_result)
        if output_file:
            print(str(db_result), file=output_file)
    else:
        error_msg = (
            f"[bold red]No results found in database for UUID:[/bold red] {uuid}"
        console.print(error_msg)
        if output_file:
            print(error_msg, file=output_file)
    rule_msg = f"[bold green]get trigger UUID:[/bold green] {uuid}"
    console.rule(rule_msg)
    if output_file:
        print("=" * 70, file=output_file)
        print(rule_msg, file=output_file)
    console.print(trigger_info)
    if output_file:
        print(trigger_info, file=output_file)
    console.line()
    if output_file:
        print("\n", file=output_file)
# Main execution
def main():
    """Main execution function."""
    uuids = read_uuids_from_file(UUIDS_FILE_PATH)
    # Create output file and directory if needed
    output_path = Path(OUTPUT_FILE_PATH)
    output_path.parent.mkdir(parents=True, exist_ok=True)
    with open(output_path, "w") as output_file:
        message = f"[bold green]Found [/bold green][bold]{len(uuids)}[/bold][bold green] UUIDs to query[/bold green]"
        console.print(message)
        print(message, file=output_file)
        for uuid in uuids:
            db_result = query_by_uuid(uuid)
            trigger_info = get_btt_trigger_info(uuid)
            display_uuid_info(uuid, db_result, trigger_info, output_file=output_file)
        # Also print to console
        console.print(f"[bold green]Query results saved to:[/bold green] {output_path}")
if __name__ == "__main__":
    main()
Output:
btt_query_output.txt (323.0 KB)
I then tried using AppleScript to delete all of the ZUNIQUEIDENTIFIERs found in the sqlite3 ... | grep fm_B command.
─   ~/projects/BTT ──────────────────────────────────────────────  3s  BTT-env  base  01:08:18 ─╮
╰─❯ osascript -e 'tell application "BetterTouchTool" to delete_trigger "68267A63-14FF-4F0E-A127-1F6DB84A967D"'
deleted
╭─   ~/projects/BTT ───────────────────────────────────────────────────  BTT-env  base  01:18:10 ─╮
╰─❯ osascript -e 'tell application "BetterTouchTool" to delete_trigger "0FCF046D-479A-4260-B8D3-A8066506B96C"'
deleted
╭─   ~/projects/BTT ───────────────────────────────────────────────────  BTT-env  base  01:18:18 ─╮
╰─❯ osascript -e 'tell application "BetterTouchTool" to delete_trigger "F623CB5B-E30E-41F2-A5CB-5ECAB4D4B21F"'
deleted
╭─   ~/projects/BTT ───────────────────────────────────────────────────  BTT-env  base  01:18:26 ─╮
╰─❯ osascript -e 'tell application "BetterTouchTool" to delete_trigger "5CEC199D-B062-4EF0-AB5F-FB6754C02032"'
deleted
╭─   ~/projects/BTT ───────────────────────────────────────────────────  BTT-env  base  01:19:44 ─╮
╰─❯ osascript -e 'tell application "BetterTouchTool" to delete_trigger "D922EC85-C539-43F9-9AAB-B01D1BCF0063"'
not found
╭─   ~/projects/BTT ───────────────────────────────────────────────────  BTT-env  base  01:19:51 ─╮
╰─❯ osascript -e 'tell application "BetterTouchTool" to delete_trigger "0C8EC140-40C2-4668-9D48-0A0AEC35C13E"'
not found
╭─   ~/projects/BTT ───────────────────────────────────────────────────  BTT-env  base  01:20:02 ─╮
╰─❯ osascript -e 'tell application "BetterTouchTool" to delete_trigger "E778E864-0CED-463F-8B96-44BC7A343833"'
not found
╭─   ~/projects/BTT ───────────────────────────────────────────────────  BTT-env  base  01:20:11 ─╮
╰─❯ osascript -e 'tell application "BetterTouchTool" to delete_trigger "E3C7B3B5-0BF3-4678-8DAC-E82DF1E1B62A"'
not found
╭─   ~/projects/BTT ───────────────────────────────────────────────────  BTT-env  base  01:20:19 ─╮
╰─❯ osascript -e 'tell application "BetterTouchTool" to delete_trigger "C18D2D13-73D3-4A0C-8F0F-D55279F8EA7D"'
not found
╭─   ~/projects/BTT ───────────────────────────────────────────────────  BTT-env  base  01:20:27 ─╮
╰─❯ osascript -e 'tell application "BetterTouchTool" to delete_trigger "F97BBC1E-54C0-488D-8C84-F5B8F688AFCB"'
not found
╭─   ~/projects/BTT ───────────────────────────────────────────────────  BTT-env  base  01:20:34 ─╮
╰─❯ osascript -e 'tell application "BetterTouchTool" to delete_trigger "C481ABCE-C455-4524-B991-3DC68530B5B5"'
not found
╭─   ~/projects/BTT ───────────────────────────────────────────────────  BTT-env  base  01:20:42 ─╮
╰─❯ osascript -e 'tell application "BetterTouchTool" to delete_trigger "CB9C8D62-1205-4378-A96A-BFB2D838057A"'
not found
unfortunately i’m traveling for the week, but I think one thing that would help is having a „triggers that recently ran a script“ section in recently used. That would already helped multiple times.
Might only get to that next week, let’s see
I've also had this idea – great minds think alike :wink:
I hope you have a great time traveling – and if it's with your family, I hope you have quality time with them!
Yep, a short family vacation and after the awful weather in Munich last week, this week has been beautiful :wink:
I added a basic "Recently Did Run Script" section in 5.305 alpha. However it might not yet catch all script calls, I have only tested the basics.
@Andreas_Hegenberg
I just updated to the latest Alpha version:
  • BTT Version: 5.307 (2025040807)
  • Alpha: 0 update(s) behind latest Alpha version 5.307 (2025040807).
I navigated to the Recently Did Run Script section, but I wasn’t able to see any script calls logged there. As you mentioned:
It seems that the phantom temporary variables are being set only at restart, which might explain why the new section is not catching these script calls.
I also have some additional details that may assist with troubleshooting. This issue began after I completely redefined my Master BTT preset on February 6, 2025. At that time I had attempted to run get_triggers, which caused BTT to crash. To work around this, I created a new empty preset and rebuilt my Master preset – importing some, but not all, of my previous triggers. Although it took time and wasn’t entirely straightforward, my new preset now runs get_triggers without issues (see BTT crashes when calling get_triggers and calling reveal_element_in_ui for triggers in all apps doesn’t work for more details).
I really appreciate your efforts in troubleshooting these issues. Having such cluttered temporary variables has made working with BTT more challenging and has raised concerns about potential configuration corruption.
Thanks again for looking into this, and I hope the additional information is helpful for your diagnostics!
one question: are you sure these are temporary variables and not persistent variables?
You can check here:
5.311 alpha (uploading now) should catch more script runs
Thanks for continuing to try to fix this, Andreas – I appreciate it!
Unless I'm mistaken, these definitely look like temporary variables and not persistent variables.
I just updated to version 5.312 and the script runs don't appear to be getting caught.
  • BTT Version: 5.312 (2025041404)
  • Alpha: 0 update(s) behind latest Alpha version 5.312 (2025041404).
ah wait, these all look like standard BTT variables that are set automatically. Is it any specific variable you are looking at?
I thought all of these variables were created by me (not standard BTT variables):
  • mouse_screen_x
  • fm_B_hovered
  • fm_B_hovered
  • focused_screen_x
  • fm_A_hovered
  • focused_screen_y
at least these are automatically set when floating menus are used in BTT:
  • mouse_screen_x
  • focused_screen_x
  • focused_screen_y
the fm_A / fm_B ones are custom, but they could also come from a "set variable value" action configured somewhere - not necessarily a script. Especially if they only contain btt-undefined
I just created a new preset called "EMPTY_PRESET" and set it as my master preset. Running osascript -e 'tell application "BetterTouchTool" to get_triggers' | jq outputs [], confirming there are zero Triggers defined in the current preset.
When I restart BTT and navigate to the Scripting BTT section in the Settings, I see that these Temporary variables are being created automatically and are not from BTT:
  • fm_A_hovered: btt-undefined
  • fm_A_menu_item_hovered: btt-undefined
  • my_test_variable: btt-undefined
EDIT:
Also, no triggers show up under "Recently Did Run Script".
ah these are definitely caused by BTT's automatic variable declaration, which happens e.g. after launch. BTT takes all triggers that have a "set variable value" action assigned and makes their variables available - this is done across presets, currently even for disabled ones.
In 5.316 I have limited that to enabled presets. Also I added some logs that allow to identify which trigger was responsible (~/Library/Application Support/BetterTouchTool/Logs )
defining variable XXX from trigger YYY - parent ZZZ
Amazing – this issue is resolved in 5.316!
Thank you so much, Andreas :slight_smile:
