Native 4 finger swiping speed
(Very much a first world problem but I might as well ask)
Is there a way to change the speed of the MacOS native 4 finger swipes? I am always slightly frustrated by how much I have to move my fingers to move between spaces
I switched to a BTT 4 finger swipe for Mission Control, but for lateral swiping I am attached to the way the spaces slide proportionally to the scrolling
I understand this is probably difficult to fix with BTT, but since it can change the scrolling speed I thought it might be possible
Or maybe there's a way to change the setting natively? a Terminal command or something
Does anyone know of a forum or Subreddit that would have an answer?
unfortunately that is not possible. Maybe at some point I‘ll add the animated space change to BTT
I was digging a bit and found out about Yabai, a command line tool that apparently lets you manage windows and turn off all window animations to move faster
I found out about this thanks to this guy, who uses Yabai with BTT, and also gives a way to speed up the Mission Control animation
Unfortunately I didn't manage to install Yabai, and the mission Control speedup didn't work for me... I'll try again soon
