Hallo,
I have a question about the "Named triggers" which have a conditions defined.
As you see in screen A, there are two "Named triggers" with the same name, but have different conditions.
When I use the action ( screen B ), are both "Named triggers" evaluated first and then only one is actually triggering because of the condition defined?
or
do I have to make sure that I have always unique named triggers names (with different conditions) defined and call them after each other ?
who would be able to help ?
thx,
Christian
Running:
BTT 3.9993 (2193) / Mac M1 Max OS 13.2 Beta (22D5038i)
BTT plugin Stream Deck option
Stream Deck Mobile (on iPad Air) latest version
