mysterious beep on drag and drop.
I am testing an app that we are developing.
it implies drag and drop between controls in a window.
on my computer I always hear a beep when mouse released/drop ended, and I have discovered that closing BTT it disappears...
I have no idea where to search the cause, settings or triggers or actions
have a look at the "recently used" section in BTT, it would show if anything is getting triggered by your drag.
Solved, but in a more mysterious way than the problem.
to check better what was triggered, i have removed all the elemts in "recently used"
the beep has disappeared :face_with_diagonal_mouth: :man_shrugging:
do you remember what elements you had there? Then I can probably tell which caused the beep
NOW I have realized that I was not deleting the recent used history, but the trigger themselves!!!! :see_no_evil_monkey:
OK, I have time machine active, what exactly should I retrieve from backup?
Unless you cleared BTT's trash, the triggers should still be in there:
OK, thank you!
now my triggers are there again but also the beep.
I'll check recent items and let you know.
Thank you!
I don't see nothing new in recent items, still I have the beep
