I'm trying to write a script that brings up a dialog box, with the options "Yes", "No", and "Quit all apps".
I just can't get my buttons to work. I want it to that when I press "Yes", it quits the frontmost app, when I press "No", the alert box disappears, and when I press "Quit all apps", I want every app to quit except Finder and BTT.
here is my script:
global frontApp, frontAppName
set frontApp to first application process whose frontmost is true
set frontAppName to name of frontApp
tell process frontAppName
end tell
end tell
set buttonSet to {"Quit all apps", "No", "Yes"}
return display alert "⌘Q" message "Are you sure that you want to quit " & frontAppName & "?
Any unsaved changes will be lost." buttons buttonSet as warning
if the button returned of the result is "Yes" then
tell application frontApp
quit
end tell
else if the button returned of the result is "Quit all apps" then
-- get list of open apps
tell application "System Events" to set theapps to name of every application process whose visible is true and name is not "Finder"
set keepapp to {"BetterTouchTool"}
-- quit each app
repeat with closeapp in theapps
if closeapp is not in keepapp then quit application closeapp
end repeat
else
return "cancelled"
end if
help is appreciated
thanks
tell application "System Events" to set FrontmostApp to name of application processes whose frontmost is true
display dialog "Are you sure that you want to quit " & FrontmostApp & "? Any unsaved changes will be lost." buttons {"Yes", "No", "Quit all Apps"} with title "⌘Q" default button 1 cancel button "No"
if the button returned of the result is "yes" then
tell application (path to frontmost application as text) to quit
else if the button returned of the result is "Quit all Apps" then
set allApps to displayed name of (every process whose background only is false and frontmost is false) as list
end tell
-- leave some apps open
set exclusions to {"Finder", "BetterTouchTool"}
-- quit each app
repeat with thisApp in allApps
set thisApp to thisApp as text
if thisApp is not in exclusions then
tell application thisApp to quit
end if
end repeat
end if
This should do it.
Here the script to get an alert style window:
display alert "⌘Q" message "Are you sure that you want to quit " & FrontmostApp & "? Any unsaved changes will be lost." as critical buttons {"Quit all Apps", "Yes", "No"} default button 2 cancel button "No"
end tell
-- quit each app
end if
end repeat
end if
Even though I do not understand the sense of the script. Any app that does not automatically a backup before quitting does already display a native alert:
got this error when running the alert one
You didn't paste the last end if
line.
this is awesome! one problem, the quit all apps button quits all apps except the frontmost app. I'm wanting it to include the frontmost app, is this possible?
Upsi my bad.
Replace the -- get list of open apps
paragraphs with this one:
set allApps to displayed name of (every process whose background only is false or frontmost is true) as list
end tell
(Basically the line just changed "and frontmost is false" to "or frontmost is true" - this way you quit all apps that are open but hidden by ⌘H and the frontmost app, but not background apps like BTT -when no window is open-, Alfred, or such helpers).
Caliguvara saves the day again! thanks so much!
