My keyboard shortcut Cmd+Shift+V doesn't work for showing clipboard/pasteboard-history
Note:
Before bug reporting, please make sure you have tried the latest (alpha) version of BetterTouchTool and that you have already tried to restart your system :-).
→ Yes I’ve done.
If you encounter a crash, please attach a crash log from the macOS Console.app from the "User Diagnostic Reports" section.
→ Whenever I input “Cmd+Shift+V”, macOS sounds “tik”, so I’ve checked Diagnostic Reports in Console.app, but nothing has shown for today, so it’s not a crash, but I have no idea why it sounds tik
→ I’ve made a keyboard’s shortcut “Cmd+Shift+(V or ㅍ)” ; which means, I’m Korean, so Vstrok also inputs ㅍ if I toggle the default physical Macbook’s keyboard and also default LanguageInputMethodEnvirnment-I’ve just made the word; for BTTclipboard Manager, to show or hide a clipboard/pasteboard-history.
But nothing happens but just tik sounds.
Actually the shortcut was for the same function executed by PasteMe.app, but I quitted it before I’ve tested BTTclipboard Manager, but the shortcut doesn’t work. If I start PasteMe.app again then the shortcut works well, being executed by PasteMe. So I’ve deleleted PasteMe.app in Application section in Finder, then have tested the shortcut, but still same symptom happens, it sounds tik.
I just wanna replace the execution of the shortcut from PasteMe into BTTclipboard Manager…
→ Macbook’s default physical keyboard, Macbook’s default trackpad
Originally, the function; showing or hiding clipboard/pasteboard-history; has been set to be triggered by touching the trackpad once with 3fingertips, and still so. I just wanna add one more way to trigger the function with keyboard’s shortcut “Cmd+Shift+(V or ㅍ)”
  • Type of Mac: Apple M1 Max
  • macOS version: Sequoia 15.6.1 (24G90)
  • BetterTouchTool version: (please post the exact version - not just "the latest one"): 5.701(2025 10 17 04)
I also have discarded PasteMe.app from Login-item list.
Already done but nothing changes → I’ll restart my Macbook to resolve this symptom, because I just only deleted PasteMe.app. They reason why I upload this post in advance is just I have no idea to save this long draft writing and my background-task for AI Claude Sonnet 4.5, that’s why I firstly upload this draft/writing.
I found that when I try to strike Cmd+Shift+(V or ㅍ) if the cursor is focused on a text-input-field on a webpage, it works as same as Cmd+(V or ㅍ).
Shortcuts added to the clipboard manager group are only active while the clipboard manager is visible. If I understood your post correctly you'd need to move that shortcut to the all apps section.
You’ve saved me, thank you so much! It works!!!
