Running the last version of BTT and Logitech Software the mouse is experiencing a noticeable lag that only goes away after killing one of the processes. Because of Logitech drivers are more customizable uninstalling them is not an option and I don't want to give up on BTT either. So, is there any way to enable mice drivers from BTT?
I'd appreciate some instructions, thanks
EDIT: my issue was solved and it was not related to BTT after all. Thanks anyways
