When using "Show/Hide Specific Application" with an external monitor, windows sometimes become unreachable.
- Multiple Desktops (the MacOS window management feature) is NOT in use
- I suspect that "move Hidden Window To Current Desktop" is to blame, and that windows are being moved into "empty space" (off the screen) when they are focused by BTT
- Using a special trigger to resize & replace the topmost window (see screenshot 3) I am able to work around. This problem seems to abate when I select "Don't Change Desktop"
- N/A (although triggers are configured via shortcuts)
Trigger to fix:
- Type of Mac: Mac Air M1
- macOS version: MacOS 14.5
- BetterTouchTool version: Version 4.630 (not alpha)
Proposed solution: change desktop but NOT screen when reactivating windows, or replace windows to ensure that they are still visible
