The "3 Finger Swipe Down" seems to required more of a "Drag" motion that a "Swipe" or "Flick."
The "3 Finger Swipe Up" however you only need to Swipe/Flick, which is the preferred length of touch action
MacBook Pro Trackpad, Magic Trackpad 2
- Type of Mac: MacBook Pro M1 Max 16"
- macOS version: Monterey 12.3.1
- BetterTouchTool version: 3.756
I don't know if this makes a difference, but I have the "3 Finger Swipe Down" configured to activate "Application Expose." It just seems like the swipe down motion is not captured well by BTT, as its not consistent in detecting multiple finger downward swipes.
I don't have the same inconsistency if I switch to MacOS built in App Expose gesture.
