When BTT is on the scrolling with two fingers on the very right and left edge of my MTP2 will not be recognoized. However wehn BTT is off scrolling on the very edges work without any problem.
MGTP2
- Type of Mac: MBP 2015 (15")
- macOS version: Mojave (10.14.6)
- BetterTouchTool version: 3.562
Having this issue since many years (changing thumg recognition setting didnt help; problem persist sin all apps). Any ideas what could maybe cause the issue?
I once asked the same question here: Trackpad Scrolling on the right edge is not possible? (Bluetooth Magic Trackpad)
