MPV Player: Run Apple Script not running my script anymore
This trigger isn't running the script anymore. I'm running
version 4.637. This used to work sometime in the past.
(btw I also cannot turn off "run in background (limited support)". it just reenables itself on each Save.
The script is here: bettertouchtool/mediaplayback.scpt at trunk · mkozjak/bettertouchtool · GitHub
The script runs well, for example, when I run the IINA app. It successfully toggles playback. But when I trigger it via touch bar button, nothing happens.
My config:
    "BTTActionCategory" : 0,
    "BTTLastUpdatedAt" : 1722241025.2054439,
    "BTTTriggerType" : 629,
    "BTTTriggerTypeDescriptionReadOnly" : "Touch Bar button",
    "BTTTriggerTypeDescription" : "Media Control",
    "BTTTriggerParentUUID" : "C331A6DA-E76E-4226-ADF6-D2A21C453510",
    "BTTTriggerClass" : "BTTTriggerTypeTouchBar",
    "BTTUUID" : "64BF1673-89F9-4FD0-95AB-42E9D226C42F",
    "BTTPredefinedActionType" : 195,
    "BTTPredefinedActionName" : "Run Apple Script (async in background)",
    "BTTAdditionalActionData" : {
      "BTTScriptType" : 0,
      "BTTTouchBarAppleScriptPath" : "\/opt\/dev\/github.com\/mkozjak\/bettertouchtool\/mediaplayback.scpt",
      "BTTAppleScriptRunInBackground" : false,
      "BTTTouchBarAppleScriptString" : "Brightness Slider",
      "BTTTouchBarAppleScriptUsePath" : true
    "BTTAppleScriptFilePath" : "\/opt\/dev\/github.com\/mkozjak\/bettertouchtool\/mediaplayback.scpt",
    "BTTInlineAppleScript" : "Brightness Slider",
    "BTTEnabled" : 1,
    "BTTEnabled2" : 1,
    "BTTOrder" : 1,
    "BTTMergeIntoTouchBarGroups" : 1,
    "BTTIconData" : "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",
    "BTTTouchBarButtonName" : "Media Control",
    "BTTTriggerConfig" : {
      "BTTTouchBarItemPadding" : 0,
      "BTTTouchBarButtonColor" : "55.000000, 55.000000, 55.000000, 255.000000",
      "BTTTouchBarApplyCornerRadiusTo" : -1,
      "BTTTouchBarItemPlacement" : 1,
      "BTTTouchBarIconInvert" : false,
      "BTTTouchBarButtonFixedWidthCutOff" : 0,
      "BTTTouchBarAlwaysShowButton" : false,
      "BTTTouchBarButtonHoverColor" : "248.880000, 146.115000, 128.010000, 181.050000",
      "BTTTouchBarButtonHeight" : 15,
      "BTTTouchBarButtonWidth" : 70,
      "BTTTouchBarItemIconHeight" : 24,
      "BTTTouchBarItemSFSymbolDefaultIcon" : "playpause.fill",
      "BTTTouchBarButtonUseFixedWidth" : 1,
      "BTTTouchBarAlternateBackgroundColor" : "75.323769, 75.323769, 75.323769, 255.000000",
      "BTTTouchBarItemIconType" : 2,
      "BTTTBWidgetWidth" : 400,
      "BTTTouchBarBorderColor" : "255.000000, 255.000000, 255.000000, 255.000000",
      "BTTTouchBarItemIconWidth" : 20,
      "BTTTouchBarFreeSpaceBeforeButton" : 0,
      "BTTTouchBarButtonFontSize" : 15,
      "BTTTouchBarIconTextOffset" : 5,
      "BTTTouchBarLongPressActionName" : "Show Music Controls",
      "BTTTouchBarOnlyShowIcon" : true,
      "BTTTouchBarButtonCornerRadius" : 6,
      "BTTTouchBarFreeSpaceAfterButton" : 2
I only did a quick test with Apple Music, it seems to work ok there. (play/pause).
Does BTT have the permission to automate IINA on your machine?
Nope. Hmm, I need to see how to fix that. Thanks!
Weird, but now I'm not sure whether any app will show up there. Let me try with IINA
Ah for IINA the script is using command line commands, these probably won't trigger the automations permission.
However it also doesn't work with IINA for me
Yeah, this did work with older BetterTouchTool versions, but I don't know which ones, though. I'm on Ventura.
How did you try the script in IINA without BTT?
I currently don't think this can be related to the BTT version as the script seems to be running for other apps, in my case Apple Music. (And once BTT successfully starts the script, it's up to the system what happens)
Cloned my repo, then cd /opt/dev/github.com/mkozjak/bettertouchtool and osascript /opt/dev/github.com/mkozjak/bettertouchtool/mediaplayback.scpt. It toggles playback on IINA that way. The script itself uses do shell script to write to IINA's socket (mpv specification).
ah I didn't have socat installed.
Could you try using the full path to socat and jq? I'm not sure what environment variables are set when running through apple script. They might also differ when being run through terminal via osascript
e.g.
if (get name of every application process) contains "IINA" then
		-- Define the socket path and command to check if playback is paused
		set mpvSocket to "/tmp/mpv-socket"
		set pauseCommand to "{ \"command\": [\"get_property\", \"pause\"] }"
		set trueValue to "true"
		set falseValue to "false"
		-- Send the get property command and capture the response
			set pauseResponse to do shell script "echo '" & pauseCommand & "' | /opt/homebrew/bin/socat - " & mpvSocket & " | /opt/homebrew/bin/jq -r '.data'"
		end tell
		-- Check if the response is true or false
		if pauseResponse = trueValue then
			-- Send command to set pause to false
				do shell script "echo '{ \"command\": [\"set_property\", \"pause\", false] }' | /opt/homebrew/bin/socat - " & mpvSocket
			end tell
		else
			-- Send command to set pause to true
				do shell script "echo '{ \"command\": [\"set_property\", \"pause\", true] }' | /opt/homebrew/bin/socat - " & mpvSocket
			end tell
		end if
		return
	end if
It seems to work fine here
OMG that was it, probably some $PATH entry that wasn't exported via applescript. Thanks!
Just an additional note:
This works with other implementations of the mpv player.
The socket path may need to be defined in your config file. (mpv.conf)
input-ipc-server=/tmp/mpv-socket
