Move Window to Left/Right monitor
Like the "Maximize Window Left/Right" I would like to chose the direction when I move a window to a monitor, instead of "Next".
You can use the "Custom Move & Resize" action to achieve this.
Cool! I got it working by setting it to: 1 Screen, left/right, from window display.
On a side-note I had some trouble understanding the text "Use this monitor when setting the new position for a window".
Might I humbly suggest something like "When setting the new position for a window, choose this monitor:"
Or not, either way thanks a lot :slight_smile:
Yep this UI will soon be replaced by something more understandable :smiley:
It's very powerful as it can basically do any window position and size, but it's not easy to understand.
I'm not sure I follow the process here. I'd like a shortcut to move one screen left or right. Moving left is easy "move window to next monitor" does that. Moving right is proving elusive. Using custom move/resize I go go to screen 3 (furthest right) but cannot move right one screen at a time. How can I do this?
Thank you for the suggestion, got this to work! Yays!
