Move window to current virtual Desktop
Hello, I'm looking for a way to move a window from, let's say, virtual Desktop 2 to virtual Desktop 1 without having to switch to Desktop 2 first. So I want to bring a window that's open on another Desktop and currently out of view into view inside the current Desktop. I tried to accomplish this by using the "Custom Move / Resize Window" action with the configuration below, but no luck. I confirmed that the window title is correct.
Is there any way to get the expected behavior?
unfortunately this is not possible with BTT because there are no system API for this.
Ok, thanks, that's too bad.
I'm also trying to achieve this. Would like a hotkey to move my iCal app to my current desktop. The best solution I found was to quit then re-open the app. It's slow, but works. Would be tougher with an app that takes longer to startup though, or that has work that needs to be saved before close.
Screen Shot 2021-09-06 at 10.29.17 AM
