This function works well with other applications except for one app I am using.
I understand that when I use move window function, it automatically moves the mouse to the top left corner of the window and click+ control+arrow.
The problem is, I am using Whale browser, and when I use "move window" function, it clicks the first tap of the browser, and I get moved to the tap instead of going to next space.
This is not a problem with BTT, this is because of my browser.
I want to know if I can make a shortcut that does the same thing by combining new functions instead of the functions that have already been created in BTT.
I am not sure if I clearly explained my problem with my poor english, but please tell me if there is a workaround way I can use by combining other functions.
- Type of Mac:
- macOS version:
