Grateful BTT user here with lifetime license, first time posting. I have recently started expanding my use of BTT (mostly for window snapping/manipulation) and I absolutely love it. However, for the first time I have encountered a bug that doesn't seem to be going away and would really appreciate it if anyone here can figure out what's going on and offer a solution. Much thanks in advance.
Note:
- BTT version: 4.468 (same result with previous versions)
- Device: M3 MacBook Air 13 in (same result on M1 MacBook Air 13 in)
- macOS: 14.4.1 (same result in macOS 13.6.5)
- I have restarted my system multiple times but same result.
- This issue does not result in a crash of BTT.
- The bug concerns "Move window one space/desktop right/left" and "Move window to desktop 1,2,3..."
- I use keyboard shortcuts as triggers ("option + right/left arrow" to move right/left; "fn + shft + b~/, h~' " to move to specific desktops).
- The shortcuts don't work every time; however, they do work once every few tries (sometime 4, sometimes 10...).
- Every time I press the shortcut, the cursor momentarily jumps from wherever it was on the screen to the top left area of the focused window (red arrow in the screenshot below) and then jumps back to its original position.
- If I move one finger across the trackpad (no other keys pressed) the moment the cursor jumps to the top left area of the focused window, the window moves accordingly.
- Assigning different shortcuts yields the same result.
Below is a screen recording of the action performed multiple times.
