I must be missing something really obvious, but I can't figure out how to move existing triggers to a folder/group... how can I accomplish this?
Screenshot: Zight 2025-06-25 at 9.59.09 AM
hallo @gtburdell
drag and drop should work...
I definitely tried that haha :-). When I try to drag and drop... it multi-selects.
Quick screen recording: Zight 2025-06-25 at 17.59.05
did you modify your standard mouse buttons behaviors? (dragging usually doesn’t do that)
Thanks for the response... nope... I haven't modified anything related to the mouse... it functions the same way if I use my mouse or the touchpad.
can you drag files in other apps correctly? (e.g. in finder)
Yep... I don't have this problem using any other software :-\
Anyone else experiencing this?
