Hi. Is there a way to move mouse cursor to and from external monitor? A quick way to move mouse cursor between monitors?
You can use the "Move Mouse To Position" action to move the mouse to a specific position.
If you use the "Cycle through multiple actions" meta action, you can cycle between multiple positions
Thanks for quick reply. Noticed that this is found in mouse but not trackpad. Is there any reason not for trackpad setting?
Not sure how I missed that previously. Thanks.
