"Move Left/Right a Space (Without Animation)" boundary check uses wrong display on Tahoe
Setup: BTT 6.183, macOS 26.3.1 (Tahoe), 3 displays with separate spaces.
Bug
"Move Left/Right a Space (Without Animation)" (actions 527/528) has a split behavior on multi-monitor setups:
  • The actual space switch correctly targets the display where the cursor is positioned
  • The boundary check ("reached end" in logs) evaluates against the keyboard-focused display instead
If the keyboard-focused display is at its last space in a given direction, BTT logs "reached end" and aborts — even though the cursor-positioned display has spaces available in that direction.
Reproduction
  1. Have 2+ displays with separate spaces
  2. Place cursor on Display A (which has multiple spaces to the right)
  3. Keep keyboard focus on Display B (which is at its rightmost space)
  4. Press trigger for "Move Right a Space (Without Animation)"
  5. BTT logs reached end and does nothing, even though Display A has spaces to the right
From the BTT log:
triggering action Move Right a Space (Without Animation) - 0A68291E...
reached end
Pressing "Move Left" first succeeds (Display B has room left), then "Move Right" also succeeds — confirming the boundary check targets the keyboard-focused display while the actual switch targets the cursor display.
Expected
Boundary check should evaluate against the same display that the space switch targets (the cursor-positioned display).
Workaround
Adding "Bring Window Under Cursor to Front" (action 204) as the trigger-level action before the space switch in the action sequence shifts keyboard focus to the cursor display, making the boundary check evaluate correctly.
Note
This worked correctly pre-Tahoe (macOS 15). Tahoe likely changed how display keyboard focus relates to cursor position, exposing a latent inconsistency in the boundary check logic.
Could you check whether the behavior improved with 6.264? I made some changes that could help.
I don’t know if it’s related to the changes described above, but in 6.271 my “without animation” left/right commands no longer work at all. Changing them to the older version with animation works.
Setup: 26.3.1, two displays, two spaces
weird, it still seems to work fine here, could you try disabling the bounds check using this terminal command?
osascript -e 'tell application "BetterTouchTool" to set_user_defaults key "BTTDisableSpaceCheck" numberValue 1'
Yes, that fixed it. Maybe the problem is related to the fact that I have two monitors, and the Space occupies both monitors? (the system setting “Displays have separate Spaces” is off.)
ah yes, most likely. I'll check with that setting!
I have added some special handling for the "Displays have separate Spaces” is off scenario
Yes, I set “BTTDisableSpaceCheck” to 0 and with the newest version the “without animation” versions do work. Thanks!
Hi. Is there any chance that you guys are adding “without animation” to the move to specific desktop feature? I like the instant feeling of the left and right controls. but often i need to move quickly from desktop 1 to desktop 7 or whatever
unfortunately afaik that is not possible (without disabling SIP)
ok, thanks for the quick response
I think I was able to implement this in 6.571 alpha (uploading now), the "Switch To Desktop X" actions now have an option for instant switching
