Move into "Notch" when connect to external monitor
Weird little bug.
I enabled several actions on "move into notch". When my macbook is folded and connected to an external monitor, the "notch" actions are activated right in the middle of my main screen.
Is this a bug? Should I restrict "notch" actions on the resolution of my internal monitor?
Thank you so much
I think that is a bug, I'll look into it! For now you could restrict the actions as you mentioned.
Second this! Can't believe I only just thought of programming some cool features into the notch. Such a wasted opportunity for macos. Have got a "mini dock" that flys out the top of the screen with other common apps i use, which is epic BUT... same issue as above. Any external monitor connected... doesnt work and triggers at a random point in the screen. Conditional triggers dont seem to work. Even though I seem to have generated them correctly and they register as "TRUE" when I test it in BTT, still doesnt work.
For anyone else struggling, the workaround for now if you have NOTCH triggers, is to set the "trigger" to be when "mouse mouse to top edge of screen" and then set the mouse "POS" coordinates to be of a similar location, inside the conditional triggers. So that when you move your mouse on ANY monitor to the very top of the screen, within a certain range, it triggers. For example, mine is set when "mouse pos percent_x" is greater than 40% and less than 60%, which is within the top CENTRE portion (notch sort of size) part of the screen only, that way you dont trigger it when fishing around on the left and right sides of the menu.
Hope this helps someone else in the meantime that this appears broken. But if we could get an answer on this would be AWESOME cause I spent WAY too much time headbutting my desk today over this haha. Additionally worth noting - ANY external monitor is connected, BTT doesnt even know that my notch on the Macbook exists anymore, even if i hover to it. Completely broken unless i am working ONLY on the MB screen. Super strange. HELP!
