Mouse Scrolling Can't be Detected or Triggered
I'm on 4.947 (latest according to the software). I'm trying to make it so when I scroll up and down on the mouse, while I hold the cmd key, it zooms instead of scrolls up and down. Can't seem to get this to work. I'm trying to tackle this in Normal Mouse window, is this where you usually create your own Master mouse settings?
Andreas, in fact, the mouse wheel can only function properly with either the Mos or BetterMouse software; otherwise, scrolling becomes nearly impossible. However, once BetterMouse and Mos are activated, the wheel detection in BTT either fails or experiences significant lag.
You can check that after installing and using BetterMouse, if you set the BTT wheel for volume adjustment, you will find that when both software programs are running simultaneously, the wheel cannot smoothly adjust the volume.
@Andreas_Hegenberg
I confirm this is still happening. I am using the latest 5.157 version, and I am using a Logitech Master Max 3S mouse with Logitech Options+ installed.
I have tried to quit Options+ but it seems to reopen by itself, so I removed the ability to do "Input Monitoring" for Logitech Options+ in the system. After which BTT is able to detect actions and execute actions appropriately via the scroll wheel!
Unfortunately you lose all the shortcuts set in the Options+ app (for example I had one of the side buttons as mission control), but most importantly also lose the ability to set the Scrolling type. For example, I don't like the "Free Spin scrolling" and would rather have the ratchet. Is there a way to have both apps running and working? Or at least the ability to mimic the behavior?
(I have come across this interesting video by AFadingThought on YT who explains how there is some hierarchy for apps: Essential Apps to Make the Most of Your Mouse - How I Set My MX Master 3S as a Power User.
I may be able to trigger BTT action from another app, but it's one more app to install)
this solution worked on corsair scymitar mouse
