I just installed BTT in order to get tap-to-click and double tap-to-right click working with my Magic Mouse (1st gen I believe). However when I'm zoomed in with the Desktop Zoom and use the configured actions, the clicks are often not matching the actual position of the mouse onscreen. In editable text fields this means the cursor will be some characters offset from where I clicked or land outside the field completely, and clicks in the menu bar frequently hit the wrong icon (which is when I first noticed the issue). Zooming out completely resolves the issue. The issue also does not occur at all with the trackpad, nor with the default physical click behavior of the Magic Mouse, it is only with the configured BTT actions.
Magic Mouse
Unfortunately it is hard to get a screenshot because the built in screenshot tools on macOS don't seem to capture the text cursor or mouse cursor, even with the option for the latter turned on.
- Type of Mac: 13" Macbook Pro early 2015 (MacBookPro12,1)
- macOS version: 10.15.4
- BetterTouchTool version: BTT v3.365, tried v3.368 as well
As noted above zooming out completely makes the issue go away, but that's not really a solution for me.
