Mouse gesture recognition certainty for straight lines
@Andreas_Hegenberg can you please clarify how to use these two mouse gesture recognition settings?
"Required recognition certainty to trigger" and "Disable rotation normalization."
I often accidentally trigger one gesture when drawing another.
For example, when I draw a vertical line, it will sometimes be recognized as my horizontal line gesture if I draw it slightly at an angle.
straight lines are hard to recognize for the algorithm used - regardless of these settings. (Although it should work if you don't use too many).
There is an undocumented way to make them work better:
Thanks, @Andreas_Hegenberg! I'll try renaming my four lines gestures with up, down, right, left, and see how it works. :grinning:
This trick seems to help a lot! Thanks for the suggestion. I'd love to see this added to the UI for better discovery.
What is happening in BTT when you use those names?
Also, does it override the options "Required recognition certainty to trigger" and "Disable rotation normalization," making them irrelevant?
it switches to a different algorithm that is (only) suited for recognizing 8 types of straight lines :slight_smile:
Maybe I can make this automatic
@Andreas_Hegenberg I updated to 5.750 today on Tahoe 26.1 and this is broken. Some of my straight-line mouse gestures are triggering the wrong action after the update. I’m still using the undocumented “Identifying Name” trick, but something has changed. How can I troubleshoot and solve this? Thanks!
there has not been a change to this recently, did you just upgrade tahoe or BTT?
Does the recently used section in BTT show anything weird?
@Andreas_Hegenberg Thanks for the help! A second restart of the Mac and BTT appears to have fixed the issues. Sorry for the false alarm!
