Hi, this is similar to the request from here: Keyboard/Mouse: Device Specific shortcuts
For some reason, the gesture button, which gives Cmd+tab, no longer specifically includes a particular device, even when the works on keyboards for same type option is enabled. Is it possible to detect specifically the mx master 3? Thanks!
I just tested this (poster of the thread you referenced), as it broke for me a while ago and haven't gotten to see if it can be fixed.
Seems the type is different, depending on if you connect it via Bluetooth or the USB dongle.
I re-recorded the shortcut, and again, selected Keyboards of same type setting and it's working as expected.
I'd try to delete the shortcut and re-record it in the Keyboard Shortcuts section.
