Hello,
I have just installed v4.839. After executing mouse gestures, they no longer work. After releasing the trigger button for the mouse button (right mouse button), the mouse gesture capture is not cancelled. You have to cancel it with Escape, so that the capturing process is cancelled at all. The mouse gesture does not work at all. Some other things do not work either, such as the space bar. I.e. Command + Spacebar no longer works. Or the right mouse button in general. Once you have executed the mouse button that no longer works, the right mouse button (which was also the trigger for the gesture) no longer works at all, anywhere. If you quit BTT, the space bar works again, as does the right mouse button.
I have not changed the configuration since the update, so that is not the cause of the error.
Many other shortcuts work unchanged and as they should (keyboard shortcuts, moving the mouse pointer in corners etc).
Thanks for your help ![]()
Note:
no crash
- Type of Mac: M1 Pro
- macOS version: Sonoma 14.6.1
- BetterTouchTool version: (please post the exact version - not just "the latest one") > v4.839
