"Mouse Clicks" Shortcutrs integration
BTT exposes a portion of its functionality to the Shortcuts app, though most (all?) of the BTT actions within Shortcuts lack a description or any documentation. In the case of the "Mouse Clicks" action, it seems to be incomplete. There are two fields to edit: number of clicks, and button to click. Clicking the "more" arrow reveals two additional options: Modifier keys and trigger behaviour (up/down/both). The issue is with the modifier keys option. The field description is "Use Currently Pressed Modifiers:" and the choices available are "use currently pressed modifier keys" and "specify modifier keys manually". One would expect that choosing that second option would either open an additional menu to specify the keys, or that it would ask when run, however neither occurs. I am trying to script an Option+Click in Shortcuts. Help!
