Mouse Chording (e.g. switch desktops with mousewheel while right mouse button is pressed)
Hi! Apologies if this has been asked before, I didn't find anything in a brief search. My question is: can I do mouse chords in BTT? For example I would like Mousewheel to switch between virtual desktops while right mouse button is pressed. Any help is appreciated!
Interested in this as well.
Any updates on this? I actually use the side button hold and drag mouse left, right to switch between apps, but that is provided by another app. I want to be able to do that with BTT, so I wouldn't need the other app anymore.
For that best use BTT's drawing gestures. If you don't want an on-screen display you can make them inivisible.
In general for chording you can often make use of the Advanced Trigger Conditions "currently_pressed_mouse_buttons" variable.
I would love to see this feature on BTT, just like steer mouse, I can press left and right click at a same time to trigger my own menu or middle click + scroll up or down for my other automation. Please consider to add this feature :slight_smile:
steerMouse
That should be possible using the advanced trigger conditions and ensuring that the conditions you need are met.
E.g. on a scroll up trigger, add a condition that middle mouse button is pressed
It's working :slight_smile: , but only for left and right click combination, for scroll up + middle click not working.
any update?
nowadays you can record multi button combinations (or button +scroll)
This has been what I've been trying but the problem is the action that is triggered by the individual buttons are still triggered.
For example i have a thumb button mapped to Opt + space to open Alfred.
Then tried to map that button plus another button (wheel tilt/horiz scroll for example); when I trigger that, the mapped action runs but alfred also opens
Also to reply to other comment and keep things in one thread, I actually tried switching the trigger to button up only and it still triggers after releasing the button combo
you are right there seems to be an issue in the current builds, let me check!
It should now be working fine in 6.281 (uploading)
totally fixed, thank you very much! Now i just need to figure out buttons+mouse swipe. I haven’t been able to get straight line gestures to work well with the advanced condition of “current mouse button down
EDIT: Seems the problem fixed itself when I unchecked right button for gestures. Now the right click is not triggering when I use a chord that includes the right button.
It’s actually perfectly fixed for mouse buttons but could it also be done for the right click? I feel like that would be more complex maybe. When I have a chord that involves a mouse button + right click, the “normal” right click menu still comes up
I wanted something similar (switch desktops when holding right button + mouse 4), so enabled the AI assistance, connected it to Codex (5.5) and asked it to do it. It did a bunch of voodoo (no seriously, i saw it writing something like assembly code at some point) and then the gesture appeared and working correctly
