More triangle swipe gestures
There's currently four triangle swipe gestures defined:
Triangle Swipe Top Left Corner: tpTriangleSwipeTopLeft
Triangle Swipe Top Right Corner: tpTriangleSwipeTopRight
Triangle Swipe Bottom Left Corner: tpTriangleSwipeBottomLeft
Triangle Swipe Bottom Right Corner: tpTriangleSwipeBottomRight
The top ones goes from the corner, and then left or right.
The bottom ones goes from the corner, and then down.
I'd love to also be able to go from the top corners, and then up. And from the bottom corners and then left or right.
Triangle Swipe Top Left Corner Up: tpTriangleSwipeTopLeftUp
Triangle Swipe Top Right Corner Up: tpTriangleSwipeTopRightUp
Triangle Swipe Bottom Left Corner Left: tpTriangleSwipeBottomLeftLeft
Triangle Swipe Bottom Right Corner Right: tpTriangleSwipeBottomRightRight
Regards
/P
