Under 1o.14 Mojave BTT trackpad behavior is not consistent. Pressing (thumb) single click, sometimes turns out as a force click because for some reason the pressure to reach the force click is extremely low and then again normal. So lightly pressing single click leeds very often to click-click (force).
Magic Trackpad 2
- Type of Mac: 27 retina iMac
- macOS version: 10.14 18A347e
- BetterTouchTool version: 2.536
Best regards,
Reinier de Groot
NB. Problem is there when I add a 2 finger click option. Yes I have this option switched off in my trackpad settings
