Modifier on Razer Keypad is overwritten by Key when recording shortcut
Note:
Before bug reporting, please make sure you have tried the latest (alpha) version of BetterTouchTool and that you have already tried to restart your system :-). If you encounter a crash, please attach a crash log from the macOS Console.app's "Crash Reports" section.
Keyboard Shortcuts: While recording a shortcut, Pressing a key on the Razer Tartarus Pro that outputs the 'Option' key will be overwritten when pressing another key (e.g. one that outputs 'x'). The same thing happens with any modifier.
  • Type of Mac: Mac Studio (M5 Max)
  • macOS version: 27.0.1
  • BetterTouchTool version: (please post the exact version - not just "the latest one") 6.939
I think there might be a misunderstanding. Keyboard shortcuts on macOS always require at least one modifier key AND a normal key (press both simultaneously to record).
Maybe you can explain what exactly you are trying to set up.
There is a thumb button on the Razer Tartarus Pro that outputs the 'Option/Alt' Modifier. I was trying to use the "Click to Record Shortcut" to record 'Option+x'. When I hold the 'Option' button down it displays the 'Option' key symbol. When then type the 'x' key the 'Option' symbol is then overwritten by the 'x', when I should see 'Option'+'X' in the record shortcut entry field. When I use my keyboard to record the same shortcut, this behaves as expected. It just happens to only behave this way with the Tartarus Pro keypad.
Also, I have found that remapping keys on the Razer Tartarus Pro will now also remap the same keys on the main keyboard even though I specified the Razer Tartarus Pro.
Both these used to work before I ran the update.
are you referring to a macOS update or BetterTouchTool update? (I don't think anything changed in BTT related to this, but maybe macOS changed something?)
A BetterTouchTool Update
I was able to get it to work. I had to completely uninstall the BetterTouchTool and install it and then recreated the key mappings. Sorry for the false alarm. Not sure why it got confused
