I have a brightness slider on my Touch Bar that I only want visible while holding control, but it will not adjust the brightness in this scenario. Instead, the widget slides up and down without changing anything. When I make the slider permanently visible (without pressing a modifier), it works as expected.
I recently upgraded to Catalina but the problem existed before the update.
- Type of Mac: 2019 MacBook Pro
- macOS version: MacOS Catalina 10.15
- BetterTouchTool version: 3.206 (1382)
