Note:
When super bright is toggled on, using mission control makes the screen blank. Super brightness has to be turned off to see mission control. Adjusting brightness still works, but screen is still blank. Behavior has been this way through multiple MacOS and BTT software updates
Using MacBook Pro M1
Screenshot of blank screen
- Type of Mac: MacBook Pr M1 16"
- macOS version: Sonoma 14.0
- BetterTouchTool version: version 4.273
Toggling Super Brightness OFF after activating mission control, shows mission control. But turning super brightness off and on each time I use mission control is a bit cumbersome.
