In mission control in macos 27, when using a keyboard shortcut to activate Close Window Under Cursor (Works in Mission Control), the window closes, but then any window that I'm trying to maximize or resize afterwards won't let me go in the area where the dock should be at the bottom (while having the dock in the system settings as hidden; this used to work in older macos versions). This behavior seems semi-random, as with some applications it happens all the time and with some it doesn't. I've been able to replicate this behavior most consistently with the System Settings app.
Also in mission control, the action to Quit App Under Cursor seems to not work at all, nothing happening to the window nor the app. Again, this was a feature that worked perfectly in older macos versions.
- Type of Mac: MacBook Pro M1 Pro
- macOS version: 27.0
- BetterTouchTool version: 6.842 (2026092104)
