The “Other Current State” view in the Advanced Conditions pane lists variables focused_screen_(x|y|width|height) which cannot be selected in the dropdown menu for variable selection.
I would like to use these to implement snap areas with custom ratios (additionally to the default ones, so I don’t want to change them) which work with multiple monitors. If there is an easier option, that would also be great.
- Type of Mac: MacBook Pro 2019
- macOS version: 12.6
- BetterTouchTool version: 4.023 (2240)
For now, I just use the position of the mouse instead.
