Missing entries in Stage Manager's Context Menu
There is an erratic of unexpected behavior when using “Stage Manager: Show in Context Menu” feature is used.
The issue is present when the “Show recent apps in Stage Manager” is enabled. As you can see in the Screenshots below, “Spotify” app was not present in the Context Menu. However, curious thing is that if I disable “Show recent apps in Stage Manager”, “Spotify” appears as expected.
I suspect there might be an internal arrangement or the scan function is not being refreshed when the toggle is active.
Incorrect information displayed in the main screen. No hardware errors, only software.
  • Type of Mac: Macbook Pro
  • macOS version: Tahoe 26.4.1
  • BetterTouchTool version: 6.426
