mimic using trackpad for dragging/double tap to drag
I have "Use trackpad for dragging" (under Trackpad Options) disabled because using Tap to Click with it on adds like a .2s delay which I hate so much
However, this disables being able to double-tap-to-drag. Instead, I have to manually click to drag something which I find tiresome.
Is there a way BTT can mimic the normal double tap to drag?
unfortunately there is currently no way to mimic this in a good way with BTT. I'm not sure whether there is any other app that could help with this.
I wasn't a fan of the delay when I started using macOS, but is is a core part of Apple's dragging concept (allows to lift your finger when you reach the edge of the trackpad and still continue dragging)
