Hi.
I've just stopped using BTT via Setapp and purchased a standard BTT license. However, my latest triggers (set in Setapp) aren't in the standalone BTT. And my Setapp subscription has just ended so I can't export the triggers from there manually, unfortunately.
I followed @Andreas_Hegenberg's advice to my previous problem (where I needed to migrate BTT settings in the reverse way, i.e. from the standalone to the Setapp version) and renamed m.hegenberg.bettertouchtool-setapp.plist to com.hegenberg.BetterTouchTool.plist which took care of the setttings, but not the triggers (as Andreas explains in the post, they are managed differently anyway).
My BTT folder in Application Support:
How can I retrieve my latest, Setapp triggers, please?
I perform daily TimeMachine backups in case some files have been deleted or changed due to Setapp.
Thank you for any and all help.
