MIDI Triggers Section - UI - Show MIDI Event Viewer
Hi Andreas,
Here is another UI bug I found in the MIDI section (and a functionality suggestion).
Thanks a lot,
zorze
Description
- In dark theme, Show MIDI Event Viewer window has black text on a black background, which is unreadable.
Steps
- Select trigger
- Button : Show MIDI Event Viewer
- Unreadable MIDI commands in window MIDI Viewer (experimental)
Notes
- It would also be useful to filter MIDI messages. For example, the message Active Sense $FE/254 is useless and fills all the space. So a filter field with ! 254 or 159 would hide the Active Sense messages.
- Other ideas, see application MIDIMonitor
https://www.snoize.com/MIDIMonitor/
Specs
- BTT version : 3.373 (1597)
- MacBook Pro (15-inches, late 2016)
- MacOS Mojave 10.14.6
