MIDI Triggers Section bug
Hi I'm trying to use MIDI and a keyboard as a huge Touchbar.
The major problem is that item Trigger if value / velocity / ... is: is not exported/copied
(same thing with item Only for device with this name:)
Might be a regression, see
Thanks,
zorze
Specs
  • BTT version : 3.365 (1582)
  • MacBook Pro (15-inch, Late 2016)
  • MacOS Mojave 10.14.6
Description
  • Settings not saved in exportation of presets or copy of triggers
Steps
  • Create trigger
  • Setup trigger
    • Only for device with this name:
      • Keystation
    • Trigger if value / velocity / ... is:
      • Greater than X:
  • Copy trigger
  • Paste trigger
  • Setup of pasted trigger:
      • :arrow_right: *
      • :arrow_right: Select when to trigger:
Thanks for reporting!
Could you check whether this is fixed in 3.366? (currently uploading, will be available as alpha update in ~5min)
Ah dang, I think I found the issue and was able to reproduce now! One moment it should ne an easy fix.
Hi Andreas,
Thanks fo your quick response.
The Trigger if value / velocity / … is: can be pasted and retain its value.
But the Only for device with this name: is still reverting to an * .
I think it should now be fixed!
Yes, working perfectly! :smiley:
It corrected another bug, where Only for device with this name: was not considered.
(If you don't mind, I found some more. I'll trickle them slowly! :upside_down_face:)
