Hi, I use an old MIDI pad for shortcut keys. It's great, but I'd love to have MIDI Output as an action or a setting available so I can set the light on the pads. Right now it works perfectly, but all the pads are unlit and with different layers you can get quite turned around.
I'd love midi out too. is this possible @andreas even by a third party app trigger?
