I just found on GitHub a useful Apple Script for muting the microphone in BTT, which also contains a variable that can be used to display a HUD notification. In short, it works, the microphone turns it off/on, the HUD also pops up, but the text is reversed. When the microphone is muted, it will write
Unmute and vice versa.
Don't know what's wrong? Of course, I can replace the texts with each other, but then the script will work differently than I would expect.
Thanks.
Script
set inputVolume to input volume of (get volume settings)
if inputVolume = 0 then
set inputVolume to 80
set_string_variable "micState" to "🔊Unmute"
end tell
else
set inputVolume to 0
set_string_variable "micState" to "🔇MUTED"
end tell
end if
set volume input volume inputVolume
set_string_variable "micVolume" to inputVolume
end tell
