Just a quick question... is anyone else's menubar not showing up? I have it set to visible in menubar mode. The mini one will sometimes show up in widget mode
You mean while using the Notch Bar? Which version of BTT are you running?
Yeah! its 4.053. It's just black. Ive tried starting from scratch just to see if it was a me issue
it just randomly started working on standard screens- still not notch screens
okay it might. be because I have 2- one is for notch and one is for standard. I just lumped them both into the same widget and put both to menubar mode only and it's working now!
