Is there a way to make a custom menubar icon change depending on the background color (something like how the actual menubar icons behave)?
if you use a black/white/transparent png icon, BTT/macOS does this automatically
Should color invert automatically with text as well? (I have an apple script that returns text)
Here are the settings I am using:
Text stays black on black background (in fullscreen menubar)
Unfortunately not, I should probably add this as an option.
It should also work to return a different color depending on the mode using Apple Script
if (dark mode of appearance preferences is true) then
return "{\"text\":\"dark mode\",
\"font_color\": \"100,200,100,255\"}"
else
return "{\"text\":\"light mode\",
\"font_color\": \"50,200,40,255\"}"
end if
end tell
However this doesn't seem to work currently. I'm checking what's wrong here.
