When I try to change the size of a menu, it will only change to make it bigger but not to make it smaller. The preview shows the change applied but not the real menu. Is anyone else experiencing a similar issue?
if you change the minimum width or minimum height, it will not necessarily update as this doesn't invalidate the current width/height. However it should then allow you to drag / resize it manually to your new minimum size
I was trying to drag it but I didn't know why I was able yesterday but not today. It turns out it had something to do with having both a mouse and a magic trackpad connected. After connecting and reconnecting the trackpad, it's now allowing me.
I think it will be useful to have fields to set the desired fixed size directly by numbers without having to drag manually.
Thanks again for your help and for being so responsive!
