menu changes position randomly after hovering
created a menu which changes size after hover. however when hovering the menu for several times the position (y-axis) of the menu changes randomly.
I hover the menu, menu changes size. go off the menu. changes size back. - ok
I hover the menu, menu changes size. go off the menu. menu jumps some 200 pixels up.
Also sequoia beta? (if possible always mention this, because work to fully support sequoia will start in a few weeks)
yes, sequoia beta 2
sent video of the behavior via email
the problem with this behaviour is that in this way the menu gets hidden under the dock or moves completely outside the screen. the only way to get it back is to restart BTT.
could you check whether setting a very small value (0,01) for the un-hover animation, fixes this?
no, didn't help. even after BTT restart
could you check whether v4.646 (alpha) fixes this for you?
Hi Andreas, unfortunately not. Behaves still the same as reported.
weird, I tried a lot but am unable to reproduce it (I'm on beta 5 now).
Maybe you can create a basic example that you can share with me?
