Maximizing windows to left & right half problem
Hi, has there been a change in the "Maximize Window Left/Right Half" function in BTT, or have they done something on the OS side?
You can see my settings in one screenshot, and the result in the other. Just a week or two ago, if I maximized two windows side by side like this, there would be no gap between them, around them, or between them and the menubar. As you can see, there are now gaps there. Is it possible to fix this back to the way it used to be? Thanks!
Ok, looks like there was some kind of an update, and I could revert to the original method in BTT settings. Problem solved.
