I have purchased a single key keyboard for use as a mouse clicker on my Mac (I have a disability and have difficulty using a traditional mouse). I am trying to set it up with Better Touch Tool to perform the following actions:
- One key press equals one mouse click
- Two key presses equal a double mouse click
- Holding the key down initiates the drag and releasing it drops the drag.
Using the macro software that came with the keyboard, I have assigned it to the F13 key so that Better Touch Tool will recognize it. However, I am only able to get to step 2 in my sequence. My single click works, double click works, but click and drag will not work at all.
Any suggestions?
