Map Control+Shift+Left Arrow/Right Arrow to Option+Shift+arrows
I'm trying to map:
Control+Shift+Left Arrow to Option+Shift+Left Arrow
and
Control+shift+Right Arrow to Option+Shift+Right Arrow
But it's not working. Its selecting the entire line, instead of just the single word.
I'm coming from Windows so this is muscle memory from 30 years.
remapping is not function of btt
I'm talking about a key combination that triggers the corresponding key sequence.
for me it is work as intended, try restarting btt
https://i.imgur.com/csA8k2u.png
Ah, I was creating it under Key Sequences, it needed to go under Keyboard Shortcuts. It works now.
