Many actions aren't visible or selectable
Actions within my Action column are not visible / not selectable / not changeable
Any
these are all from within the Music app but applies to any app (Brave Browser SS below)
Music-specific settings screenshot
Brave Browser normal mouse settings
  • Type of Mac: MacBook Pro (Retina, 15-inch, Mid 2015)
  • macOS version: macOS 12.7.6 (21H1320)
  • BetterTouchTool version: (please post the exact version - not just "the latest one")
    • 6.147
    • (this started happening when I upgraded from either 5.34 or 5.736 to a 6.0+ version. I think. Maybe 6.010?? It’s hard to tell because I have auto-update on & i didn’t report this when I first noticed it)
It doesn’t matter what UI settings I have selected (outline list view or extra columns). It’s not just the Music app. It’s not just trackpad settings (attached another screenshot for Brave Browser normal mouse settings)
i HAVE previously tried uninstalling everything and reinstalling. sorry if that screws things up for debugging :sweat_smile:
Let me know if you need any other information
exported debug info attached
version 5.762 does not have this issue
version 6.055 does not have this issue
version 6.062 does not have this issue
version 6.063 HAS this issue
something in this version broke it
i’m going back to version 6.062 for now until this is fixed
edit: again i’m on macOS 12.7.6 Monterrey just fyi
edit 2: reading through the forums, it seems there have been a lot of fixes for Logitech mice since 6.062, so I don’t know what version to use now :sweat_smile: :sweat_smile: :sweat_smile: . If I upgrade, I can’t make changes to actions unless I completely re-create all those triggers anew :sweat_smile:
Thanks a lot I was hunting this issue for a while but the only other user that encountered it was super angry and didn't want to provide debug details. With your detailed analysis I immediately figured out what's wrong. Will be fixed with the next alpha!
