When using chrome on lichens.org Right click on a mouse usually allows you to draw arrows on the chess board. When bettertouchtool is turned on there is just a strange red line in a gesture box. After a few drawings the MacBook will go to sleep and turn on again (having to put my password in).
I have quit bettertouchtool and was able to use the mouse fine after with no shutdowns.
External USB Mouse
- Type of Mac: MacBook Pro (Retina, 13-inch, Early 2015)
- macOS version: 12.6.3 (21G419)
" BetterTouchTool 4.017 is currently the newest version available.
(You are currently running version 4.017.)"
