Hi - new to BTT. Loving it so far.
I have a question however, is there a way to do tap and hold on the trackpad? I.e., I tap it and then hold it for “x” seconds and THEN the action triggers? And if you lift up ahead of “x” seconds, it doesn’t trigger the action.
I have played around with duration as an advanced condition and I can test it in the advanced condition screen (and it works), but for whatever reason, I cannot get it to trigger actions as intended. I have tried the following:
- 4 Finger Tap -
- Advanced Condition - trackpad_touch_duration >= 3
- Action is just HUD for now to see if it works.
- I cannot get this to work.
- Also have done 4 finger tap
- If Condition
- True - same action as above (HUD)
- Else - Nothing
- End
- If Condition
I have also tried a few other things (although I am less familiar with them):
- Creating Trigger 1
- Four Finger Tap
- Setting a variable (i.e., TouchTimer = 1)
- Putting a pause for 3 seconds
- Setting the same variable to Touchtimer = 0
- Using a second trigger
- 4 Finger Tap (Step 2)
- Using Advanced Conditions to only allow it if Touchtimer = 0
I get the feeling Tap is only edge driven at the moment of tap and then it doesn’t capture anymore. Maybe holding is too similar to swipe at that point?
Thanks for the help!
